Old 11-11-2016, 07:08 PM   #1
Tiger Joe
79 c30 4wd swap
Will a Dana 60 bolt up to a 2wd frame?
Obviously I know I will need to add the hangers for the leaf springs, but is there anything else?
My dad has a 79 c30 dump we will be working on this winter and debating if we wanted to do a 4x4 swap. Have a lead on a dually Dana 60 locally
Tiger Joe is offline   Reply With Quote
Old 11-11-2016, 08:20 PM   #2
74CustomK20
74CustomK20's Avatar
Re: 79 c30 4wd swap
Front spring perch width didn't change from 73-87 1/2 to 1 ton. The rear changes from 3/4 to 1 ton so beware of that. And you might have to change the crossmember so watch out for that.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 11-15-2016, 09:37 AM   #3
Tiger Joe
Re: 79 c30 4wd swap
Everything I am working in its all 1 ton driveline.
so the frames from c30 to k30 are the same? someone told me they are different?
Old 11-15-2016, 09:48 AM   #4
andrewmp6
Re: 79 c30 4wd swap
The frame its self is the same.But the steering box steering linkage the whole front suspension and engine crossmembers are different.Is that dump truck a cab and chassis truck ?
Old 11-15-2016, 10:42 AM   #5
Tiger Joe
Re: 79 c30 4wd swap
Yes cab and chassis
Old 11-15-2016, 11:52 AM   #6
DieselSJ
Re: 79 c30 4wd swap
If I were looking to convert 2wd to 4WD, I'd try to dig up one of the 5-link, coil-over kits.
DieselSJ is offline   Reply With Quote
Old 11-16-2016, 02:32 AM   #7
andrewmp6
Re: 79 c30 4wd swap
I believe you might get away with keeping the rear end it has now just use taller springs.But the whole front will have to be changed out.Its not super hard its been done just takes time.And what trans and t case you want to run ?
