11-15-2016, 11:34 AM | #1 |
Sound Deadener and Heat Suppression
Has anyone successfully used any of the products from E-bay or Amazon that doesn't carry the price tag of Dynamat. Or have a recommendation as to what might be a good option. Truck in pieces, on the way to a restoration. Would like something economical but real satisfactory. Thanks
Smitty '71 Short Fleetside Spring Valley, Ca. |
11-15-2016, 12:39 PM | #2 |
Re: Sound Deadener and Heat Suppression
I know there are cheaper versions but I used Dynamat extreme and am VERY pleased with the results. You can listen to the radio and carry on a conversation while running 70 mph down the road.
LOWER IT AND DRIVE IT Sally's thread http://67-72chevytrucks.com/vboard/s...d.php?t=563266 |
11-15-2016, 12:42 PM | #3 |
I've used FAT MAT http://www.ebay.com/itm/FatMat-100-S...8nqEcA&vxp=mtr on two cars and am very pleased with it. Still not cheap but cheaper than Dynamat. It comes in differ amount if you don't need too much.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
11-15-2016, 12:44 PM | #4 |
I have used fat mat , pretty much the same stuff as dynamat , but less expensive
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
11-15-2016, 02:09 PM | #5 |
Fat Mat is a good product, i did the entire cab floor for about $70.00.
11-15-2016, 02:22 PM | #6 | |
What was the difference? I was thinking of doing that and over the gas tank.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
11-15-2016, 03:51 PM | #7 |
It made a very notable difference.I applied behind the tank and not on the tank. make sure you tape all the seams, the road and engine heat causes the adhesive to ooze out a little.
11-15-2016, 04:10 PM | #8 |
Do a google search fatmat vs dynamat. There is some interesting comparisons.
http://www.caraudio.com/forums/gener...d-dynamat.html
11-15-2016, 04:58 PM | #9 |
Fat Mat was on mine when I bought it. Compared to my buddies old truck without any deadener it's night and day. I won't ever go without it again. I've used Dynamat before for car stereo things in the past and it worked as it should have also.
11-15-2016, 05:29 PM | #10 |
I have the fat mat in my cab and I wonder if I need insulation also. Any thoughts?
11-15-2016, 08:46 PM | #11 |
www.sounddeadenershowdown.com
It's a full package. Hushmat/dynamat/fatmat is only part of the equation and it is a waste of money to do an entire interior with it. Did it in my '70 with 40 series flowmasters dumping right behind the cab and it did a great job.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
11-16-2016, 08:07 AM | #12 |
I just recently purchased "Noico Black 80 Mil 36 Sq Ft Car Sound Deadening, butyl automotive deadener restoration mat and Noise dampening insulation" from Amazon and I have a buddy that uses "road kill" purchased at Walmart.
11-16-2016, 09:41 AM | #13 |
http://www.b-quiet.com/?gclid=CPGzor...FQGUaQodar4CdQ
I used the above company on the Circuit Rider - worked great.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
11-18-2016, 07:31 PM | #14 |
You can buy peel and seal at home improvement stores (lowes in my area) for a fraction of the price as fatmat and it's the exact same thing (except it doesn't say fatmat on it). I found this out after months of research. Another good thing is you don't have to order and wait for it if you run out. As far as insulation you can get frost king duct insulation at the same store. I have my entire daily drive covered in both and the difference is night and day. I've installed custom stereos since high school and wouldn't use the stuff if it didn't work.
Posted via Mobile Device Last edited by Rex'69; 11-18-2016 at 07:40 PM. |
11-18-2016, 07:40 PM | #15 |
You can buy peel and seal home improvement stores (lowes in my area) for a fraction of the price as fatmat and it's the exact same thing (except it doesn't say fatmat on it). I found this out after months of research. Another good thing is you don't have to order and wait for it if you run out. As far as insulation you can get frost king duct insulation at the same store. I have my entire daily drive covered in both and the difference is night and day. I've installed custom stereos since high school and wouldn't use the stuff if it didn't work.
Posted via Mobile Device |
11-18-2016, 08:59 PM | #16 |
X2-Don't scrimp-USE DynaMat
1972 Highlander PAC B 400BB-SOLD 1974 K5 Blazer-6.0 swap 1974 C20 Long Bed 454 1977 GMC HeavyHalf several adopted orphans |
11-18-2016, 09:15 PM | #17 | |
11-18-2016, 09:24 PM | #18 |
Not trying to argue with you but have you ever seen it melt? My truck is black and it's get over 100 degrees in the summer and nothing has melted in four years. I know this because I had one of my door cards off to replace a speaker and everything was stuck on there same as the day I put it on. I get that people like dynomat but there are a lot cheaper products that work just as well. If you have any first hand experience in it failing I'm all ears.
11-18-2016, 10:14 PM | #19 | |
11-19-2016, 12:00 AM | #20 |
Peel and stick duct insulation...18$ a roll. I agree that's hard to beat. Put the regular auto pad under the carpet....bingo....
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
05-31-2017, 10:51 AM | #21 |
Use aluminum ducting tape to tape them?
05-31-2017, 10:52 AM | #22 |
I have it over my generator enclosure in my toyhauler and it has done well, no small or melting.
05-31-2017, 10:56 AM | #23 |
Works good for me!
10-03-2017, 04:33 PM | #24 |
Did any of you use a heat shield also or do these products do double duty?
10-03-2017, 05:35 PM | #25 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=739054
