Old 11-15-2016, 11:37 AM   #1
HeloCrewChief
HeloCrewChief's Avatar
Replaced Dash Harness and now no start
I decided to replace my under dash harness since the fuse block was so corroded none of the fuses were even fully held in. I purchased an M&H unit and the install was pretty straight forward. Even with the corroded fuse block I was stilla ble to start the truck every time and the headlights, dome light, horn, and taillights worked. No dash lights worked.
After replacement, the truck does not start. Almost like a dead battery or bad starter. The only light I get anywhere is the brake light in the instrument cluster which did not previously work. Being optimistic about it at least something now works
Anyway, I've tried jiggling the ignition harness around and that did nothing. The truck is a manual transmission so, I do not think neutral safety switch is an issue. I'm thinking about pulling the fuse block back off and trying to reconnect it with the engine harness again to see if that helps.
1970 C10 to K20 conversion
1974 GMC Jimmy
1968 50th Anniversary Short Bed
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
HeloCrewChief is offline   Reply With Quote
Old 11-15-2016, 01:50 PM   #2
davepl
davepl's Avatar
Re: Replaced Dash Harness and now no start
Power comes in via the big red in the bottom right corner of the harness (facing the firewall from outside). Check that first - it's connected to the junction block, alternator, all of that.
Then check the opposite side of it (don't know the color offhand, but it should be obvious) and make sure it's coming through on that wire.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-15-2016, 02:21 PM   #3
demian5
demian5's Avatar
No magic pill here, you are gonna have to diagnose and recheck everything.
Anything anyone says would be a shot in the dark.
Good luck.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 11-15-2016, 03:36 PM   #4
badd71
Active Member
I put the inside fuse block in upside down once.
badd71 is offline   Reply With Quote
Old 11-15-2016, 07:36 PM   #5
cleszkie
cleszkie's Avatar
Does the new wiring harness come with provisions for a neutral safety switch for an automatic transmission? If so, then you will need to jump the wires to fool it into thinking the neutral safety switch is closed. Otherwise, you will not be able to start the truck.
cleszkie is offline   Reply With Quote
Old 11-16-2016, 03:38 PM   #6
HeloCrewChief
There is an extra plug that was not on my old harness in the steering column vicinity. You may be on to something there. I will try jumping that plug and see what happens.
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
Old 11-16-2016, 04:05 PM   #7
Toms67
Toms67's Avatar
You probably already checked this. Make sure all your ground wires are hooked up. And you have a good ground contact to the block and the frame. Hope this helps.
Toms67 is offline   Reply With Quote
Old 11-16-2016, 04:30 PM   #8
MySons68C20
MySons68C20's Avatar
MySons68C20 is offline   Reply With Quote
Old 11-17-2016, 04:44 PM   #9
MARKDTN
does the new wiring harness come with provisions for a neutral safety switch for an automatic transmission? If so, then you will need to jump the wires to fool it into thinking the neutral safety switch is closed. Otherwise, you will not be able to start the truck.
x2.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
