Old 11-18-2016, 08:04 PM   #1
396C-10
50 Years of wires to nowhere. My journey through the spider web.
Thinning out and removing unnecessary and dead wiring. Are you ready for a good laugh?
396C-10 is offline   Reply With Quote
Old 11-18-2016, 09:18 PM   #2
djeCST
djeCST's Avatar
Re: 50 Years of wires to nowhere. My journey through the spider web.
That looks kind of familiar - I got to that point on my truck and ended up gutting all of the wiring in favor of a new harness.
Do you have any wires that start as one color and magically appear somewhere else as a different color? Makes troubleshooting kind of challenging, doesn't it?
Dennis
'70 CST/10
'55 Bel Air wagon
djeCST is offline   Reply With Quote
Old 11-18-2016, 09:22 PM   #3
jocko
jocko's Avatar
Worse yet, mine all start as a color - but at the other end, everything ends in black. LOTSA splices and apparently the po only bought black wire...
Old 11-18-2016, 09:24 PM   #4
Toms67
Toms67's Avatar
OMG. They don't make enough beer. For that job. LOL.
Toms67 is offline   Reply With Quote
Old 11-18-2016, 09:38 PM   #5
projectking
projectking's Avatar
That's a job for hard liquor! I'll post a pic tomorrow of my '68's under dash job, let's just say I feel your pain!
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 11-18-2016, 09:49 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
What's your plan and how can we help? think about any upgrades you might want to go to so you can plan the wiring for them.
HEI ignition
External to internally regulated alternator.
Headlight relay mod.
Electric cooling fan(s)
Work off the electrical forum.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-18-2016, 09:54 PM   #7
Dustmaker65
Dustmaker65's Avatar
I just finished wiring a '70 that was a drag truck for 30 yrs! They must of thought that wire weight a ton, because they cut everything inside and outside. I built my own engine harness and bought a pretty nice light harness off the classifieds here.
If I was you(or I run into this again) post on the classifieds that you need a complete harness...someone will come to your rescue.
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 11-19-2016, 04:25 AM   #8
396C-10
HEI ignition
I am leaving the essential wiring, all of that was 50 years of stereos, CB radios and a few things I don't even know what they are..... Like this thing. LOL!
This was up under the dash just above the throttle pedal, and I have no clue what it is.
Old 11-19-2016, 04:27 AM   #9
396C-10
Originally Posted by djecst View Post
that looks kind of familiar - i got to that point on my truck and ended up gutting all of the wiring in favor of a new harness.
several! Lol!
Old 11-19-2016, 04:31 AM   #10
396C-10
I think my original existing is actually in good shape. All of that was excess from years of accessories and the like. I did add an alternator with an internal regulator, so that actually eliminated a bunch of wiring.....
Old 11-19-2016, 04:39 AM   #11
396C-10
This is what I am working with. I swapped the small block 3 speed column shift for an LS 396 t-400. After wiring is done, all I have to do is press in the U-joints and install the drive line, bleed the brakes and an altitude tune up. I dropped 9000 ft since installing the engine and I am sure it is set lean.
Old 11-19-2016, 10:12 AM   #12
clay68c10
clay68c10's Avatar
Nice truck! I used to have a red/white 68 twin to yours. Your 396 will like all the air at lower altitude.
I'm guessing you're not in Wyoming anymore. Texas??
It looks like your PS belt isn't quite aligned, maybe just the pic.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 11-19-2016, 10:46 AM   #13
Orange Crate
Orange Crate's Avatar
X2 on a new harness from American Auto Wire. Easy install and you can order it with upgrades for HEI, VSS and additional accessories.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 11-19-2016, 11:53 AM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Nice '67 and a beautiful engine. Have you considered ditching the flex fan for electric fan(s)?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-19-2016, 02:20 PM   #15
396C-10
I moved to the Jackson Mississippi area. Good eye on the PS pump pulley. I need to flip the pulley, or get one for a long water pump set up. I will work those bugs out in time.... Good eye though!
Old 11-19-2016, 02:22 PM   #16
396C-10
Thank you for the hook up on the wiring harness. That will be on the list of things to do. Much appreciated!
Old 11-19-2016, 02:25 PM   #17
396C-10
Yes, this is all temporary until I work the bugs out of it. At idle, sitting still during 2000 rpm/20 minute cam break in, it hit 190 degrees and I fanned water into the radiator with the garden hose and brought it down to 175 and held. I will need a shrouded electric fan because 190 is a bit much for these heads.
Old 11-19-2016, 02:26 PM   #18
coreyjhen
That thing under your dash was a choke filter for suppressing radio noise. We used to put those in to cut down on the whine from the alternator. They really didn't work all that well, but they were better than nothing.
coreyjhen is offline   Reply With Quote
Old 11-19-2016, 02:30 PM   #19
396C-10
When I get this together and going, I will find a frame and start work on the frame and do the disc brakes, lines, wires, bushings, fuel cell & lines, paint and mounts. When the frame is done, I will switch everything over to the new frame and leave it at that.
Old 11-19-2016, 02:33 PM   #20
396C-10
Not planning on restoration or paint. It looks great with the original patina in my opinion. Once you paint over that, it is gone forever. I don't want to do that. We are a group who appreciates fade, dents and scratches. To me, each one tells a story...
