Old 11-21-2016, 08:08 AM   #1
of13swc
Upper/Lower control arm bushings??
So when or should I change my control arm bushings. I am taking my front suspension apart the have it powder coated. Is it a good idea to go ahead and remove the bushings then replace or should I just leave them and roll with it??
If I replace what's the best tool/method to do so?
of13swc is offline   Reply With Quote
Old 11-21-2016, 10:14 AM   #2
PGSigns
PGSigns's Avatar
Re: Upper/Lower control arm bushings??
You will need to pull them for powder coating so the grease won't run out and screw stuff up when they bake it. Inspect them while they are out and go from there. Need to pull your ball joints also.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-21-2016, 10:16 AM   #3
of13swc
OK thank you. Also are they difficult to remove and replace?
Jimmy
Old 11-21-2016, 02:18 PM   #4
Kenfuzed
Kenfuzed's Avatar
You can inspect to see if they are still good but personally I would just replace them since they have to come out anyway.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 10-04-2017, 01:19 PM   #5
RedRider
RedRider's Avatar
Similar question: I'm rebuilding my front-end along with a disc brake conversion. Kit came with ball joints, tie-rid ends, etc but nothing for the control arms. Should I consider doing this while I'm in there? Is there a reason control arm bushings aren't typically included in these "complete" disc concession kits? Seems like they rarely go out.
RedRider is offline   Reply With Quote
Old 10-05-2017, 07:23 AM   #6
PGSigns
PGSigns's Avatar
The reason they are not included is that they don't need to be replaced to go to the disc brakes. It is always a good idea to check your stuff when you have it down.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
