Old 11-23-2016, 01:20 PM   #1
NoForAnAnswer
NoForAnAnswer's Avatar
71 locking hub question
A couple weeks ago my driver side spindle nut backed off and took out everything from the knuckle out. So I got my upgraded parts installed and I get to the locking hubs and there's a large tapered spring behind the locking mechanism. Now, my passenger side has the spring and the drivers side the spring got mangled.
My family's had this truck since 1983 and when my dad bought it it had warn premium hubs on it.
I went to 4 wheel parts yesterday and they explained to me that spring isn't needed.
Any help would be appreciated
Here's the spring I might need.
http://www.quad4x4.com/cgi-bin/comme...cton&key=40050
71 K10, 400hp 355, TH350, NP205, 12 bolt w/Eaton posi, Dana 44 w/spartan, 4.11 gears, 32/11.50-15 Cooper STT, full length Hooker headers, Dual Thrush glasspacks, Points triggered Crane Cams ignition box, Holley 670 street avenger, Edelbrock performer manifold
NoForAnAnswer is offline   Reply With Quote
Old 11-24-2016, 04:32 AM   #2
'63GENIII
'63GENIII's Avatar
Re: 71 locking hub question
Are you asking if you do or don't need the spring or if anyone has an extra?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 11-24-2016, 04:03 PM   #3
NoForAnAnswer
If I need the spring or not. Took a look at it last night and couldn't see a need for that spring, but I've little experience at this.
Old 11-24-2016, 05:12 PM   #4
'63GENIII
'63GENIII's Avatar
I'm pretty sure it is in there to keep the hub unlocked when not in use. My 73 D44 has them on both sides. They look like they might be a cheap - not premium Warn hub.
Chris
'63 k15 long step
Old 11-24-2016, 05:23 PM   #5
NoForAnAnswer
I found this video
https://youtu.be/txoD4_kQ-3I
at about 2:30 you can see he pulls out the locking hub and you can see there's no spring behind the hub. This is what's confusing to me. Then I pulled the passenger side hub it sprung out because of the spring. But here it just sits there.
Old 11-25-2016, 01:42 PM   #6
kwmech
No spring needed with a Warn hub. Locking mechanism is different than the original Spicer style
Old 11-25-2016, 04:26 PM   #7
NoForAnAnswer
Thank you so much. So the warn premium hubs were not installed by the factory? The original owner (we're the second) had a dealer installed tow package as he had a camper. I wonder if it involved replacing the hubs as well?
Either way I greatly appreciate your help.
