Old 11-27-2016, 07:52 PM   #51
68Timber
I know the pieces fit
68Timber's Avatar
Re: Project "Candy Apple"
Beautiful. I like your formula, all your refurbs come out great. But this one, the color combos and paint are different enough that this one really stands out.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-28-2016, 08:35 AM   #52
ultrahd4me
ultrahd4me's Avatar
Thank you sir.
Follow me on Instagram: @midtennc10
Youtube channel: Midtennc10
ultrahd4me is offline   Reply With Quote
Old 11-28-2016, 08:57 AM   #53
Desert1957
Desert1957's Avatar
Bobby,
Just noticed something on one of your pics, Looks like a dent on the front edge of the bed. Was there a mishap in the garage? or is it a shadow?
Name:  IMG_1189 - Copy.jpg
Desert
Desert1957 is offline   Reply With Quote
Old 11-28-2016, 09:29 AM   #54
ultrahd4me
ultrahd4me's Avatar
I think its more of shadow than anything else, I haven't noticed it in the garage.
Old 11-28-2016, 09:43 AM   #55
Desert1957
Desert1957's Avatar
That's Good News, I like the larger rear tires on this build, No rubbing issues?
Nice work as always.
Desert
Old 11-30-2016, 10:33 AM   #56
ultrahd4me
ultrahd4me's Avatar
I only had a few minutes in the shop last night but I managed to get the new fender emblems on. I started on removing the tail light lens and housings but one has a stripped out screw and I didn't have time to deal with that crap.
Old 11-30-2016, 02:16 PM   #57
TKCR
TKCR's Avatar
I need to get mine on my truck. Did you use the tape adhesive or the studs? In which you would have had to drill holes? Mine are OEM, but I removed the studs and put the tape on them, just haven't installed them yet.
Old 11-30-2016, 02:34 PM   #58
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Looks great. Put a factory grill back in there for me though. I didn't think I would like this truck based off the before pic but it is turning out nice.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 11-30-2016, 02:41 PM   #59
ultrahd4me
ultrahd4me's Avatar
I used the studs on the emblems and barrel clip nuts on the fenders.
Old 11-30-2016, 03:17 PM   #60
ultrahd4me
ultrahd4me's Avatar
I would add a grill but I'm so for over budget I'm sticking with what I have. I honestly didn't like it either and I gave premium dollar for it too. I was lied to about how nice it was and what was left to finish. That's how is goes on some deals, and I've spent a ton of money and time but its starting to look like something I would own and drive. Basically drivetrain, paint colors, seat and dash are all that remain of the truck when I bought it, everything else has been reworked, replaced, or restored.
Old 11-30-2016, 06:36 PM   #61
dropd80s
dropd80s's Avatar
I have not had any luck sourcing the barrel clips. Where do you get yours? I don't want to buy online unless i can confirm the size! TIA
"I'm Dirk Diggler enough to own and operate a vehicle of this caliber" -veinbar
Dropped and LS Swapped SWB 87 Build Thread
dropd80s is offline   Reply With Quote
Old 11-30-2016, 07:18 PM   #62
ultrahd4me
ultrahd4me's Avatar
I can get the part # for you tomorrow. Do a google search for emblem barrel nuts, you need the ones for 3/16 stud mount. I think you redrill the hole to 7/32. I have a napa part # or most ford restoration catalogs carry them.
Old 11-30-2016, 08:51 PM   #63
dropd80s
dropd80s's Avatar
That's awesome. Thank you so much
Old 12-01-2016, 08:42 AM   #64
ultrahd4me
ultrahd4me's Avatar
Here you go: Napa # 665-1457 Body Nut / Auto Barrel Nut
Old 12-01-2016, 10:52 AM   #65
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Your system always yields nice results. Once again well done.
Old 12-01-2016, 05:17 PM   #66
dropd80s
dropd80s's Avatar
Awesome, I really appreciate it!
Old 12-03-2016, 06:30 PM   #67
ultrahd4me
ultrahd4me's Avatar
Nothing to exciting today, but small details make a big difference. Tail light housings cleaned, new bulbs, and new lens installed. I had to tweak the trim a little but the fit is good.
Old 12-11-2016, 03:55 AM   #68
TKCR
TKCR's Avatar
I am in need of a set of burgundy floormats. Looking for a older factory set that need restored. Thanks
Did you ever find floor mats? I happened to see these looking around at other parts.
https://www.ebay.com/itm/201734988033
Old 12-11-2016, 03:53 PM   #69
UKNOWME
UKNOWME's Avatar
Originally Posted by UKNOWME View Post
So what's you opinion of Crown Suspension.
Not sure if you saw my question but I'm real curious what your opinion is.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 12-11-2016, 03:54 PM   #70
UKNOWME
UKNOWME's Avatar
Looks very nice! Are those OEM lenses and trim?
1964 Chevy c10
Old 12-11-2016, 06:19 PM   #71
ultrahd4me
ultrahd4me's Avatar
I started this weekend with the last stage with this truck, the dreaded engine compartment. I found a small coolant leak right after I bought the truck which turned out to be the water pump. The truck only a small electric fan without a shroud and I doubted its ability to properly cool the engine. So as most of projects go, I ended up doing a complete cooling system overhaul. New water pump, thermostat housing, thermostat, fan, heavy duty fan clutch, drive belt, and new fan shroud. The radiator and hoses had already been replaced so they were good to go. Everything went great except mounting the new fan shroud, it looks like I was sent one for a none A/C truck. So that will get finished later this week.
Old 12-11-2016, 06:33 PM   #72
ultrahd4me
ultrahd4me's Avatar
I did and I forgot to reply. I only used their axle mounting plate and shock extensions brackets. The PO told me he got the drop spindles from them but I'm not 100% sure on that. I did see some of the same casting flaws I've seen with other brands, so they are all probably made by the same supplier. I liked everything so much I reordered enough parts for 2 trucks. Super fast shipping and they personally called to verify my order. The shock brackets taper in at the bolt hole so you don't have to use spacers like most others.
Old 12-12-2016, 01:19 AM   #73
LT7A
Question on the shock extensions, the pictures that I've seen of those make them look low enough to catch speed bumps. Is that a danger? Or are they at a comparable elevation to other components?
Old 12-14-2016, 09:23 AM   #74
ultrahd4me
ultrahd4me's Avatar
I can get you an exact measurement if needed, but the front is lower than the rear shock brackets.
Old 12-16-2016, 08:52 AM   #75
ultrahd4me
ultrahd4me's Avatar
Finally making a little progress, the new LMC fan shroud arrived and is a good fit. I still have to rework the air intake system and a little bit of trimming on the engine covers.
