Old 12-01-2016, 06:57 AM   #1
gmc 2500 4x4
front brake hose relocating kit 69 gmc 4x4
just put in a 4'' spring lift in and was looking for a vendor that offers a bracket kit front/rear. 69 gmc 3/4ton 4wd. oem lines are to short, just wonderin whats avail.
gmc 2500 4x4 is offline   Reply With Quote
Old 12-03-2016, 02:39 AM   #2
60sIron
60sIron's Avatar
Re: front brake hose relocating kit 69 gmc 4x4
I had some custom made. Took one day. Not as cheap as buying over the counter. But if the hoses are to short they're to short. Be sure to measure correctly. I measure just the length of the rubber hose. They measure end to end. Luck I add extra for good measure......... could have been a costly mistake!
60sIron is offline   Reply With Quote
Old 12-03-2016, 05:25 AM   #3
gmc 2500 4x4
i ended up makin some drop down brackets after some input from a friend. it worked out great and i am able to use my new hoses from wagner. just wanted to see if there was some brackets available.
Old 12-03-2016, 07:05 AM   #4
andrewmp6
http://www.offroaddesign.com/catalog...brakelines.htm read under the brake lines it says what you gotta do to use them
