Old 12-02-2016, 09:47 PM   #1
Hewfil1
Hewfil1's Avatar
1974 K10 1/2 ton Posi
Just as the title says. I have a 1974 K10 1/2ton truck with a 12-bolt open diff. I want a posi in it, and not air lockers. Anyone know a good one to put in, if not a full time. I currently am running 33"x12.5"x15" BFGs and it does no good for me to only have one wheel spinning.
Hewfil1 is offline   Reply With Quote
Old 12-02-2016, 10:02 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: 1974 K10 1/2 ton Posi
detroit tru trac
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-03-2016, 08:07 AM   #3
Jake Wade
Jake Wade's Avatar
Originally Posted by cochino12 View Post
detroit tru trac
That would be my pick.
Jake Wade is offline   Reply With Quote
Old 12-04-2016, 12:03 AM   #4
Hewfil1
Hewfil1's Avatar
Thanks guys. I take it it's a fairly simple swap-in?
Also, spline count for 1/2 K10? I'm not 100% sure. If I recall correctly it's a 8.875 30spline, right? Then I'll obviously also have to know my gear ratio.
Old 12-04-2016, 04:42 PM   #5
MTCK
MTCK's Avatar
Yeah you will need to know which ratio you have which would be in the glove box. I've heard good things about the trutrac and personally I had an auburn clutch type lsd that worked well. Will have to setup the gears after install so if you want to swap ratios you are 1/2 way there.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 12-05-2016, 02:43 AM   #6
Matt Man
Matt Man's Avatar
Got one in the front of my k10 and it works great no issues.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 12-05-2016, 11:17 AM   #7
Hewfil1
Hewfil1's Avatar
Even with the lockout hubs?
Old 12-05-2016, 01:52 PM   #8
Matt Man
Matt Man's Avatar
Yep no problem it is a Limited slip so it behaves very well on the street. Turns like it did with nothing in the front. I also have a np208 and warn hubs.
Old 12-05-2016, 10:12 PM   #9
Hewfil1
Hewfil1's Avatar
Got a part #?
Old 12-06-2016, 01:39 PM   #10
Jay2Cor517
Jay2Cor517's Avatar
Originally Posted by Hewfil1 View Post
Got a part #?
Detroit TruTrac-Eaton http://www.eaton.eu/ecm/groups/publi.../ct_128302.pdf
Everything that can be counted does not necessarily counts; everything that counts cannot necessarily be counted--Albert Einstein
Jay2Cor517 is offline   Reply With Quote
Old 12-06-2016, 06:57 PM   #11
Hewfil1
Hewfil1's Avatar
Originally Posted by Jay2Cor517 View Post
Thanks!
