12-03-2016, 03:14 PM | #1 |
Figuring Out Frankenstein
I've been slowly working on getting my 72 K20 4x4 back on the road. Both axles were replaced at some point with 1/2 ton axles, but I have no idea what they came from, or if they even came from the same donor.
At this point I'm tired of trying to backtrack and figure things out. I haven't had any luck finding model correct axles near me, and this was never meant to be a show queen so I'm not worried about it being "perfect." Are there other 3/4 ton axles, and leaf springs, I can easily swap in so I know what I'm working with? This is my first project, and I'm trying to do as much myself as possible, so the simpler the better. |
12-03-2016, 04:44 PM | #2 |
All about them K’s
Re: Figuring Out Frankenstein
Any front axle from 71-87(91) will bolt in and have disks. One ton 73-91 4x4 rear will bolt in but you'll have to move the shock mounts around on the axle. Other than that your stuck to 67-72 4x4 rear end being bolt in. The 73-87 rears other than one ton will work but you got to move perches and shock mounts on the axle. All 71-87 (91) Front springs will bolt in rears will not. Someone feel free to add or correct me if I missed something.
Your truck had a 3/4 ton Dana 44 and likely an Eaton ho52 rear end from the factory.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 12-03-2016 at 04:51 PM. |
