12-03-2016, 08:16 PM | #1 |
456 gears
Let me know your thoughts on 456 gears, with 34" tires, and an overdrive tranny. Has anyone used this combo?
12-03-2016, 08:29 PM | #2 |
Moderator
Re: 456 gears
Ohhh dats da kine rite there.
Whew, sometimes I think I spent waaaaay too much time off shore.
12-03-2016, 08:45 PM | #3 |
Re: 456 gears
Agree with Rocknrod! I have about the same but no overdrive
60 K20, eaton HO52, T221, SM420, Dana 44 closed 78 K20 Burb, 14 bolt, NP205, SM465, Dana 44 open 05 Dodge Ram 2500 5.9 Cummins 4x4 |
12-03-2016, 10:05 PM | #4 |
Re: 456 gears
12-03-2016, 10:23 PM | #5 |
Re: 456 gears
Perfect. Should be in the 2400 rpm range in 1:1(3Rd/4th) @ 55. Depending on OD auto or manual ratio. Mine is .69 so 75 is 2000 rpm on 315/70/17 (34.4") but 3.73
Also depends on final goal of truck. Size and power of motor.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
12-03-2016, 11:06 PM | #6 |
Re: 456 gears
Not a bad combo for highway cruising - but 1st gear will get you about 10 ft before it's time to shift into 2nd, depending on which o/d trans you have. You can always start off in 2nd too. If manual, like an NV, I don't know off the top of my head what 1st gear is, but this chart will give you an idea of the o/d effect.
Do you already have the 4.56? If not, I'd recommend 4.10 (but no higher (lower numerically) or it will start to lug the motor at lower highway speeds). Last edited by jocko; 12-03-2016 at 11:12 PM. |
