Old 12-06-2016, 12:51 AM   #1
72peace
72peace's Avatar
69 Dash with choke
So, where is the original dash location of the choke on a 69 in-line 6? I've been told they used a three hole dash like the 67-68 or an actual hole in the metal on either side of the dash. I'm trying to take it back to original and i'm not sure where it should go.
Thanks,
Nathan
72peace is offline   Reply With Quote
Old 12-06-2016, 02:00 AM   #2
72peace
72peace's Avatar
Re: 69 Dash with choke
Do i need to use a 67-68 Bezel to accommodate the choke?
Old 12-06-2016, 06:09 AM   #3
frenchy51
frenchy51's Avatar
This is my 69 Utility Body C20 396 (currently for sale on ebay)
1972 Highlander PAC B 400BB-SOLD
1974 K5 Blazer-6.0 swap
1974 C20 Long Bed 454
1977 GMC HeavyHalf
several adopted orphans
frenchy51 is offline   Reply With Quote
Old 12-06-2016, 08:58 AM   #4
notsolo
notsolo's Avatar
Probably 3 different dash bezel combinations. This 1 is wipers, lights left choke on right. Don't know if all are available?
notsolo is offline   Reply With Quote
Old 12-06-2016, 10:10 AM   #5
72peace
72peace's Avatar
It looks like I would use a 67-68 bezel to include the choke
Thanks,
Nathan
Old 12-06-2016, 11:58 PM   #6
palallin
Thanks,
Nathan
That's what I did.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 12-07-2016, 08:13 AM   #7
I think to be correct you need the 69-72 one and put the choke under the headlight switch where the wipers would be on a 67/68. The reason for this is the 67/68 bezel has "Wipers" embossed where you want choke. There is a tab to label the choke knob. That blue bezel is a 67/68, the one frenchy51 showed is correct
Old 12-07-2016, 11:47 AM   #8
frenchy51
frenchy51's Avatar
[QUOTE=special-K;7789299]I think to be correct you need the 69-72 one and put the choke under the headlight switch where the wipers would be on a 67/68. The reason for this is the 67/68 bezel has "Wipers" embossed where you want choke. There is a tab to label the choke knob. That blue bezel is a 67/68, the one frenchy51 showed is correct[/QUOTE
You are correct. Mine is labeled "CHOKE" Under headlight switch on the left.
1977 GMC HeavyHalf
Old 12-07-2016, 04:41 PM   #9
72peace
72peace's Avatar
Thanks for the info, time to break out the dremel...
Cheers,
Nathan
Old 12-08-2016, 12:01 AM   #10
palallin
I used the '67 dash and moved the wiring for the wipers over to the left side. Changing the wiring is FAR easier than changing the dash.
Old 12-09-2016, 09:21 AM   #11
68panelman
68panelman's Avatar
Get yourself a choke tab/placard like this, drill a hole under the wiper knob in location with the formed metal hole in the dash opening to bolt your choke cable to. Add choke plate and bezel retainer.
68panelman is offline   Reply With Quote
Old 09-22-2019, 08:55 AM   #12
68 TT
Still plays with trucks
68 TT's Avatar
I know really old thread but thought I would share pics of other bezel types for reference.
The one notsolo pictured is the one currently reproduced for the 67-68 models with gauges.
One of the ones not reproduced that I have on my 68 is this one. Chrome bezel from the Z62 Custom C & C equipment package and the CST package when equipped with a divorced choke carburetor from the factory.
The bezel has no raised platform with the embossed CHOKE lettering on it but the hole is there in the bezel. The hole was filled with a slightly rectangular chrome emblem with GM in the center. It has textured black paint in the center around the letters inboard of the raised chrome perimeter frame.
The emblem is the same width as the raised platform with the embossed CHOKE lettering that would normally be there and looks like it could cover the area if the raised platform were ground off. Haven't done this to see if it would work or not but might have to in order to put a new bezel into my 68 as the emblem sits flat against the bezel with no relief in the back side for any chance of it covering the CHOKE embossment intact.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-22-2019, 10:42 AM   #13
LockDoc
The Older Generation
LockDoc's Avatar
Here is how my all original '68 CST/CUSTOM CAMPER cluster looks. It has a 327 with a 4 barrel carb in it. There is a plastic plate that covers the word "CHOKE" under the chrome choke delete.
LockDoc
Leon
Old 09-22-2019, 08:30 PM   #14
2 Stovebolts
If I'm not mistaken the choke is on the upper right.....
2 Stovebolts is offline   Reply With Quote
