#2751 | ||
![]() Join Date: May 2006
Re: PO has me PO'd
we should buy stock in those companies, how' your project coming? Quote:
My sons were all taught manual before they went on to CNC Damn!!! Just spilled my first cup of coffee all over my interior, what a mess to start my day You've given me the incentive to get back on my rear mount of my rocker box area, I had forgotten about using templates for that area, but I may call Wes and order them up
#2752 |
Re: PO has me PO'd
Dang, my brass nuts hit 21/2" tail pipe
#2753 |
Re: PO has me PO'd
I really thought about it. I had them in a cart and everything from Wes. He has a lot of cool parts.
Just the thought of the fight that it would start when the CC bill shows up this month. I do have to say though, Last year at this time for Christmas my wife surprised me with the title to the Jimmy. I had the guys number in my phone for the Jimmy and she called and bought it for me... So there is that... She thought it ran and drove, and was really kinda upset that it didn't. Have a great day!
1972 GMC Jimmy - The wife HATES it! 1973 Chevy Camaro - The wife HATES IT MORE! 1994 Chevy Suburban - Never getting rid of it. 2005 GMC Yukon Denali - That's the wife's. 2012 Chevy Silverado 1500 Z71. 2005 Chevy Tahoe (May use this for a 5.3 Swap) |
#2754 | |
Re: PO has me PO'd
#2755 |
Re: PO has me PO'd
All the parts came in from unity, switch bezel, pillar mount (202), not received the actual switch itself...
[url=https://flic.kr/p/Q3utVH] ![]() somehow, I have to rotate the mounting plate for the adaptor [url=https://flic.kr/p/NFUSb9] ![]()
#2756 |
Re: PO has me PO'd
One of, if not the best reproduction sheet metal piece I have ever bought and that goes back 20 years to my English cars
Wes was very enlightening on the process of other manufactures, and his ability to only supply us with best parts out there Example, his fuel filler neck grommet, mine was about 5-10 years old, never in the sunlight and still checked and cracked, After about 1/2 hour of BSing with him, I placed my order. Always great to chat with a person, that has as much passion about his products as we are about our trucks ![]() had to cut my old one to get it on [url=https://flic.kr/p/PY3ynw] ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-13-2016 at 07:51 PM. |
#2757 |
Re: PO has me PO'd
this weeks problem....
OEM bypass spin on filter adapter.805 OD Jegs non bypass adapter.............810 OD 16 TPI tried a thread file, no luck, thought there might be a burr Put adapter on lathe, removed 5 thou. still a tight fit, but worked it back and forth with lube, seems to go all the way on [url=https://flic.kr/p/QbL8dm] ![]() I think I can clock the adapter now, once I figure out location
#2758 |
Re: PO has me PO'd
I am in the FI club, just have to install with double sided tape and get my lights working again
[url=https://flic.kr/p/P7BwqS] ![]()
#2759 |
Re: PO has me PO'd
Tuesday I order my repro hickey drop center hood
#2760 |
Re: PO has me PO'd
played with my twin stick today. what a PITA trying to hold up the shifters and start the pivot bolt by hand, so I wouldn't cross thread
Make sure to install inside shifter rail linkage first, as you can't install after the pivot, shifters are offered up ![]() [url=https://flic.kr/p/Qpsjmh] ![]()
#2761 |
Re: PO has me PO'd
been working on my twin sticks, had to order a new trans shifter mount from lokar straight 8" stick, about 4-6 weeks out
[url=https://flic.kr/p/QEoKLy] ![]()
#2762 |
Re: PO has me PO'd
[url=https://flic.kr/p/R4pKME]
#2763 |
Re: PO has me PO'd
had some spare time, to get roundtuit
buttoned up my long sleeve shirt, and safety glasses Tapped a pivot bolt, 1/4-28 grease zerk .2130 drill center drill reference only, not doing an operation at the moment. DON'T leave your chuck keys IN ![]() ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-17-2017 at 11:40 AM. |
#2764 |
Re: PO has me PO'd
![]() ![]() used drill press to bore perpendicular hole just have to pump in some grease to flush
#2765 |
2WD Jimmy
![]() Join Date: Mar 2005
Re: PO has me PO'd
What lathe is that you have?
#2766 |
Re: PO has me PO'd
just an old south bend model A, 4 1/2' bed
catalog # CL644R, picked it up a couple years ago for 100.00 I'll post up a pic as soon as flickr cooperates
#2767 |
Re: PO has me PO'd
#2768 |
Re: PO has me PO'd
#2769 |
Re: PO has me PO'd
I like the look of that chrome bezel around the side marker.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
#2770 |
Re: PO has me PO'd
Thanks, had to modify on my router table to get them to function, plastic lens had to be reworked, to light as OEM.
Nice billet alum. piece from Marquez, still have to buy 2 more for the rear
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-20-2017 at 11:19 AM. |
#2771 |
Re: PO has me PO'd
sorry for the delay, went to upstate NY to do some snowmobiling for the week, still very sore after 12 hour rides, well not exactly 12 hours, quite a few bars in
between..... problems with the location of the remote oil fill, rethink but I did make some progress on the twin stick mount, cut the hole three times and its still short on the throw, last cut clears, you have to have at least 1 1/2" from plate to the front of the stock hole to clear in high gear ![]()
#2772 |
Re: PO has me PO'd
Bummer.
If there's any room to raise the shifters UP a little bit they will work with a smaller through-hole. I remember playing that same game with the shifters on my Atlas-4. I wanted them to all line up with a common pivot point (OCD-type issues!) but AA doesn't set up their brackets that way.... -G
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well™" Build |
#2773 | |
Re: PO has me PO'd
Heard from Kurt lately, gotta give him a shout, hav'nt heard from him in a month or two next purchase is alum. atlas trans. case 2/1, and drive shaft brake. thanks for posting a link to your build, lost you for a while, very entertaining, great work, over the top build waiting for Locar to send me my 8" straight handle, probably 2 weeks out yet do you know which shifter is front and rear? can't raise them up, located by the pivot bolt
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-10-2017 at 03:04 PM. |
#2774 |
Re: PO has me PO'd
![]() One more handle to hook up, emergency brake on the driveshaft
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-10-2017 at 03:03 PM. |
#2775 |
Re: PO has me PO'd
Hey Jim,
I stop by frequently to check on progress here.. ![]() Kurt is around, seems like he is busy with his new business venture and spending time skiing with his kids.... -G
