Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 12-07-2016, 02:34 PM   #1
343CA
Rear hinge pins
Are the rear hinge pins the same size as the door hinge pins?
Who makes the rubber gasket around the barn door hinges?
Thanks in advance
343CA is offline   Reply With Quote
Old 12-07-2016, 10:15 PM   #2
padresag
Re: Rear hinge pins
yes. http://www.steelerubber.com/
ron
padresag is offline   Reply With Quote
Old 12-08-2016, 11:17 AM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Rear hinge pins
IIRC, Steele Rubber makes the hinge gaskets.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 12-08-2016, 03:44 PM   #4
343CA
Thumbs up Re: Rear hinge pins
Thanks Pad and Mike for answering my questions.
Are the outer barn door hinge gaskets the same size as the 40-59 suburban?
Old 12-08-2016, 04:11 PM   #5
padresag
Re: Rear hinge pins
if you look in the link that I gave you and fill in the listing for what you have and check it out. you will seek the knowledge that you are inquiring about
don't know whether or not if they are the same size as the earlier ones. but they have what you need.
ron
Old 12-10-2016, 08:15 AM   #6
65chevysub
65chevysub's Avatar
Re: Rear hinge pins
Does anyone make the plug that goes into the holes for the barn doors if the Sub has the clamshells? I've checked Steele, and others but all they carry is the grommet for the hinges
65chevysub is offline   Reply With Quote
Old 12-10-2016, 01:01 PM   #7
padresag
Re: Rear hinge pins
think that maybe you are SOL there !
ron
Old 12-10-2016, 01:37 PM   #8
Llay R. Rac
Llay R. Rac's Avatar
Re: Rear hinge pins
I think i saw some online a few months ago. i think it was the filling station.
i was searching "hole plugs"
i think also mc-master carr or grainger had some usable.
my original plugs are still in place but i worry they are probably about to turn to dust.
1965 Suburban, 2 wd.,292, 4-speed.
proudly owned and operated since Valentines day 1969.
Llay R. Rac is offline   Reply With Quote
Old 12-10-2016, 04:43 PM   #9
65chevysub
65chevysub's Avatar
Re: Rear hinge pins
Thanks guys. I will check both of them out. Next step is an auto paint store. They might have something that will work.
