12-08-2016, 12:53 AM | #1 |
New 7 speed wiper motor kits for 64-72 trucks from Detroit Speed!
Selecta Speed Wiper Kit A downpour of rain will no longer hinder your ability to clearly see the road. This kit provides you with the performance and convenience of a late model wiper system in a package that easily and cleanly mounts in your car. The wiper kit contains a low profile, seven-speed wiper motor with 5 delays, low speed, and high speed, rotary switch, adapter plate, and wiring harness. The CNC aluminum adapter plate mounts the wiper motor to the stock firewall bolt pattern and requires no permanent modifications to the vehicle. The supplied wiring harness uses the factory wiper grommet opening and requires no cutting of the factory harness. New improved features include: Easier Installation: The wiper switch and wiring harness plug into a wiper control module located under the dash. The wiper motor connector is already installed on the wiring harness, saving you from having to pin out the wiper motor connector. The wiring harness has also been simplified with new wiper control module design. Push Button Windshield Washer Function: The seven position rotary wiper switch now features a push button function for a windshield washer option. Once the push button function is released, the wiper blades cycle 3 times just like your current OEM vehicle. The wiper blades then continue to operate at the last switch position. The wiring harness includes a weather pack connector/harness for an inline windshield washer pump. Smaller, Lighter Wiper Motor: Modern OE wiper motor design is more compact for a clean look on the firewall giving additional clearance for your brake booster, valve covers, etc. Complete your kit with the Detroit Speed Windshield Washer Pump Kit. Currently only the 67-72 is available with the 64-66 coming soon. Price is $525 and will include free shipping. I do not have this listed on my website yet, so PM me for questions or payment details.
Mike Redpath |
01-02-2017, 05:52 AM | #2 |
Collector of Projects
Re: New 7 speed wiper motor kits for 64-72 trucks from Detroit Speed!
What is involved / included in the Detroit Speed Windshield Washer Pump Kit?
01-05-2017, 11:35 PM | #3 |
bolt in kit
Mike Redpath |
01-06-2017, 06:37 AM | #5 |
What is the price of the complete kit that includes the washer pump?
01-13-2017, 11:54 PM | #6 |
Retail is $570 with washer pump
Mike Redpath |
01-29-2017, 06:23 PM | #7 |
us 73-87 guys left out again!
67 C10 Choppin block backhalf KP Components front dropmember US Mags Rambler 20s |
05-01-2017, 07:15 PM | #8 |
Hi can you send price for 1969 with water pump shipped to 75070? Also, install instructions.
Thanks, Jeff
1969 C10 = Red /Black 402 BBC, Holley Terminator EFI, 10:1 CR, Isky Roller Cam, Weiand Stealth intake, GM Serpentine Drive , Mechman 170 amp alt, Classic Air, Dewitt aluminum radiator with black ice coating, Dual Spal fans, G-body overflow tank, 700r4 trans, 12 bolt rear, 3.73 gears and Detroit Truetrac posi |
