Old 12-08-2016, 04:02 PM   #1
Camaroguy
Camaroguy's Avatar
'68 c10 build
This build started on 09/26/2016 as a father and son project with the idea of selling it when complete. I decided to start a thread today so I'll be adding a bunch of pics in a row.
I don't have a lot of information about the truck to begin with but we started with a 1968 cab. The frame VIN matched the cab and is a short bed. It is a leaf spring truck which isn't anything I have dealt with before on these.
My dad owns his own hot rod shop (Wild West Street Rods) and they work on it it periodically throughout the day when waiting on stuff for other projects. Due to my work, I am only able to devote about three hours a day, four days a week to it.
Camaroguy is offline   Reply With Quote
Old 12-08-2016, 04:04 PM   #2
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
Here is the frame we started with. It was in really nice condition. We added a Brother's bolt in c-notch (welded) prior to sending it out for powder coating.
Old 12-08-2016, 04:06 PM   #3
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
This truck had rust in both rockers and cab corners.
Old 12-08-2016, 04:09 PM   #4
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
Rust repair continued on the other side.
Old 12-08-2016, 04:12 PM   #5
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
Rust repair continued on doors. Additionally, speaker holes were filled, and rust preventer put on the cab floors. The cab floors were actually pretty solid. We also added a high-hump transmission tunnel.
Old 12-08-2016, 04:14 PM   #6
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
Started smoothing the firewall and the beginning of bodywork.
Old 12-08-2016, 04:16 PM   #7
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
Body work roughed in on cab and it is sprayed in primer. Also, continuing bodywork on doors.
Old 12-08-2016, 04:18 PM   #8
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
Frame came back from powder coating. It is a chrome-ish color.
Old 12-08-2016, 04:24 PM   #9
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
Now the fun part (for me) begins. Assembly of suspension. We went with a 4" drop leaf in the back with a 2.5" drop shackle. We did it this way instead of flipping it, but in retrospect, I would have probably flipped the axle on top and ran a stock spring. Also, we put a 9" inch rear end in it because it was the only axle housing we had that was the proper width. It currently has 3.73 gears. I also added rear disc's. I don't remember what brand they are but I ordered them from Summit. I used dupli-color caliper paint but thinned it a little and shot it through a gun.
Old 12-08-2016, 04:36 PM   #10
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
On the front suspension, I used McGaughy's 2.5" drop spindles, with their disc brake kit. I also used a 2" drop spring from Brothers. Will most likely end up changing it to a 3" drop spring once it's all said and done. I also got the front steering re-installed.
Old 12-08-2016, 04:50 PM   #11
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
The wheels came in around Thanksgiving. I initially ordered Boss 338's but the rears I needed were back-ordered for about 10 weeks. Plan B was US Mags "Rambler" wheels. They are 20x8 front and 20x9.5 rear. I used Nitto 420S tires. I can't remember the sizes off the top of my head right now, but I think they were 255/45 and 275/55.
Also, you can see the rear discs in the final picture. They are an 11" caliper and look really small in the 20" rim. We might end up buying bigger brakes.
Old 12-08-2016, 05:05 PM   #12
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
Now to the motor. My dad had previously bought a motor from a 2009 G8 GT and decided we could use it for this build. It's a l76/6l80e combo. Only had 11k miles on it and is really clean. After reading up on these motor's they are pretty cool. Approximately 370 hp stock and 400 possible with tuning. We did have to order a new accessory drive to get everything to fit properly. Ended up ordering a kit from Holley but haven't received it yet.
We installed it with stock frame mounts moved about 3" back, and Dirty Dingo sliders. After the initial install and putting the cab back on, we decided it was way too tight against the firewall. To fix this, we installed a GMPP Muscle Car pan and put the frame mounts back in the stock location. In the first set of pics, you can see the motor is too close to the firewall.
Old 12-08-2016, 05:08 PM   #13
jricharc
Re: '68 c10 build
Sick build, gonna be bad ass!
1986 C10 LWB 350
1970 C10 LWB 350 - Sold
jricharc is offline   Reply With Quote
Old 12-08-2016, 05:11 PM   #14
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
These pics are with the motor moved forward. It looks a lot better. We will be using stock exhaust manifolds because they fit great inside the frame. Ignore the Corvette engine cover, we were just coming up with ideas.
I don't have any pics yet, but we built a two piece drive line utilizing the factory G8 front driveline which bolts to the transmission.
Old 12-08-2016, 06:45 PM   #15
GR8-68
GR8-68's Avatar
Re: '68 c10 build
This is one sweet build, also building a 68 myself
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 12-08-2016, 08:14 PM   #16
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
Thank you. I checked out yours as well. Keep up the good work.
Old 12-08-2016, 08:15 PM   #17
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
Thank you!
Old 12-08-2016, 08:23 PM   #18
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
Here are a couple of other pics I wanted to upload. It shows the test fitting of the door and filling of the gas tank filler.
Also, the Boss 338's we originally wanted to go with. I'm a little disappointed we couldn't use them because I'm partial to them on these trucks; however, there sure are a lot of these truck out there with them on it.
Old 12-08-2016, 08:28 PM   #19
FRCvette
Re: '68 c10 build
Sweet build man. I will b watching this so keep the pics coming.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 12-08-2016, 08:33 PM   #20
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
Thanks! I will be posting pics at least weakly. The goal is to have it painted by March or April.
Old 12-09-2016, 09:23 AM   #21
forcd02
Re: '68 c10 build
Great job, thanks for the pics-i am just starting my 70 build
Did you use the stock frame brackets? mine has a 6 banger, have
a 5.3 LS going in-the 6 banger used a single bolt motor mount,
I have some DD engine adapters from another project, thought I
could use them
Keep the pics coming
forcd02 is offline   Reply With Quote
Old 12-09-2016, 10:11 AM   #22
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
could use them
Yes, we used the stock frame mounts and a stock rubber mounts bolted to the Dirty Dingo Sliders on the engine. Hopefully these pics help.
Old 12-09-2016, 12:53 PM   #23
forcd02
Re: '68 c10 build
Old 12-09-2016, 04:19 PM   #24
GAc10boy
GAc10boy's Avatar
Re: '68 c10 build
Love the US Mags. Glad you went with those!
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 12-12-2016, 04:03 PM   #25
Camaroguy
Camaroguy's Avatar
Re: '68 c10 build
A few pics of the two piece drive line. We used the factory G8 front drive line into a carrier bearing.
1968, 1968 c10, c10, ls swap
