Old 12-08-2016, 06:25 PM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Arm Rest Door Panel Space
Looking at the interior door panel, once you attach it to the inner door there are two cage nuts that you screw the arm rest to. Is there supposed to be a spacer in there between the door and the inner door panel?
Old 12-08-2016, 06:46 PM   #2
pimpston65
pimpston65's Avatar
Re: Arm Rest Door Panel Space
the only spacer/eschution i know of is between the inner panel and the window crank and inside door latch. there is also the gasket that goes between the inner panel and door, i guess it can act as a spacer.
pimpston65 is offline   Reply With Quote
Old 12-08-2016, 06:53 PM   #3
The Rocknrod
Moderator
Side view? Maybe I'm over-thinking this.
Old 12-08-2016, 06:58 PM   #4
pimpston65
pimpston65's Avatar
nice computer drawing, from the 80's!!! anyway does your armrest once attached feel loose?
Old 12-08-2016, 07:13 PM   #5
pimpston65
pimpston65's Avatar
maybe this will help, its the template from the armrest.
Old 12-08-2016, 08:52 PM   #6
The Rocknrod
Moderator
That's not going to flex?
Having built my truck from a "box-o-parts" I'm not sure.
Old 12-08-2016, 08:58 PM   #7
60-66
60-66's Avatar
Theres no spacer. Ive done this several time 1959 through 1967. just the arm rest , screws and cage nuts.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 12-09-2016, 08:47 AM   #8
The Rocknrod
Moderator
No Spacer Aye.
Thank you.
Old 12-11-2016, 07:27 PM   #9
Rust-O-Matic
Rust-O-Matic's Avatar
Just put armrests on my '66. No spacers, just screws directly into cage nuts. I wondered the same thing at first, but it seems to fit just fine.
Rust-O-Matic is offline   Reply With Quote
Old 12-11-2016, 08:07 PM   #10
vince1
X 3.
I used a pattern found here somewhere but found them off a bit. Next time to get the holes spot on I would draw my own lines with panel off and on.
A welcome addition to the truck.
vince1 is offline   Reply With Quote
Old 12-12-2016, 08:55 AM   #11
The Rocknrod
Moderator
Ya I'm still workin on the Pong game.
Thanks everyone.
