![]() Join Date: Oct 2009
1964 C10 Long Wheel Base Rolling Chassis--- No Shipping
I have a 64 LWB frame with front and rear suspension. Frame looks straight and looks really clean above the rear axle where they rust. Trailing arms are clean also. Unknown brake and rear end condition. Believe it has been sitting a while. If it doesn't sell rolling then I will part it out. $450 Picked up in Shelburn, IN only. I don't have a way to ship or the time to figure out a way.
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. Last edited by Todd68Chevy; 12-17-2016 at 10:17 PM. Reason: Corrected year. |
Re: 1966 C10 Long Wheel Base Rolling Chassis--- No Shipping
Pictures
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
More pictures
Few more
I'm curious about that rear end--are you sure it's a '66 chassis? The panhard mount on the rear axle is '60-'63. In '63, they went to the corporate 12-bolt, but all of them also had a Dana 44 as the optional rear.
If it's a Dana 44, it'll have "44" on the snout. (I can't see the rear cover clearly to ID it). Otherwise, I think that rear is the '63 12-bolt. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
#6 | |
If you get ready to start parting it out, I would like the motor mounts
Good luck Mike |
#8 | |
The panhard bars on the '64-'66 are the shorter ones that go to a boss on the top of the axle housing, while the '63 had a longer bar that connected to a bracket on the axle tube, the same as the '60-62. Mounts, width, bumpers, everything else should be the same, so you shouldn't have any problems. -Brad
#9 | |
Moderator
![]() ![]() Join Date: Aug 2011
http://67-72chevytrucks.com/vboard/s...d.php?t=550400
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 12-12-2016 at 01:51 PM. |
#10 | ||
They look like the 67-72 250 six cylinder stands and if they are then I have several of those extra that I would sale. I will see if I can verify if they are the same or not.
you could be right about the engine perches being for a 6 cylinder - they looked to me like they were for a V8
If you have some for a V8 I am interested Thanks Mike |
In the 67-72 trucks the v8 and I6 are different but I was told that in the 66 and earlier the v8 & I6 are the same. I am just not sure if the 66 and earlier are the same as the 67-72 I6 stands. If you can understand what I am saying. These are in the V8 location so I would say these are correct for the 66 and older V8s. I will see what I can find out.
Thanks for checking into this
We will see what turns Up Mike |
![]() Join Date: Jun 2007
Longbed frames can be tough to move - If it comes down to parting it, I want the transmission shift linkage bracket off the drivers frame rail - the one with the ink pen shaped spear sticking out from it....held in by two rivets.
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
#15 | |||
#16 |
They look the same to me. Here is a pair I have for $35 plus shipping.
#17 |
I will let you know.
#18 |
![]() ![]() Join Date: Apr 2012
To narrow it down a little more Todd , its a 1964 frame. 1963 did not use a frame bracket for the automatic shift linkage .
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
#19 |
Thanks, It is great that we could figure out the correct year. Thanks everyone.
#20 |
Ttt
#21 |
Still available
#22 |
Sold
