Old 12-12-2016, 08:57 PM   #776
deejaaa1
Re: Loadmaster '47 COE
i think it's appropriate.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 12-12-2016, 09:09 PM   #777
Advanced Design
Advanced Design's Avatar
Rob, I hope you do the camper build here. Your problem solving and build skills are great to learn from.
Advanced Design is offline   Reply With Quote
Old 12-12-2016, 10:20 PM   #778
strider621
strider621's Avatar
Do it here Rob. Can't wait to see what you come up with.
Keith
strider621 is offline   Reply With Quote
Old 12-12-2016, 10:40 PM   #779
Bad Apache
Bad Apache's Avatar
Definitely wanna see the build! Gives me bad ideas!
1958 Apache 454ci 4 speed
Bad Apache is offline   Reply With Quote
Old 12-12-2016, 11:30 PM   #780
reaper71
reaper71's Avatar
Make it Happen Rob!!
Mark...
reaper71 is offline   Reply With Quote
Old 12-13-2016, 06:18 AM   #781
Keep her rollin here. I do not know of any campier/camping sites that would be of any help.
Old 12-13-2016, 09:32 AM   #782
47 Fasttoys
47 Fasttoys's Avatar
Take a look back on page 3, post 64 of my build thread at option 8.2. Look familiar? Not to far off for a plan made back in 11/13.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 12-13-2016, 09:56 AM   #783
47 Fasttoys
So here we go: These are some ideas of what I am going to attempt for the COE camper. These where drawn with the idea of using steel as the wall frames but I'm starting to lean towards wood. Yeah I know, some of the things in the drawing don't work out (under bed storage and dinette set), it's just the details that I need to figure out. Ha, just the details, how hard could that be?
Rob
My '47 C.O.E build
Old 12-13-2016, 10:25 AM   #784
reaper71
reaper71's Avatar
Yes sir that'll work
Mark...
Old 12-13-2016, 10:53 AM   #785
flashed
This is gonna be cool to watch .
flashed is offline   Reply With Quote
Old 12-13-2016, 04:43 PM   #786
lower50's
lower50's's Avatar
This is going to be so cool. Can't wait.
On my 18' trailer I built 7 years ago. I have steel floor frame, 2x2 steel tubes in corners then wood 2x4 supports for the walls and 2x2 roof. I then used plywood for the front V and transport trailer aluminum siding for the roof and walls. Might save a bit of weight. Also I have to paint the wood every 2 years and have yet to touch up the aluminum. Just some food for thought.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 12-13-2016, 06:23 PM   #787
47 Fasttoys
Very nice Lower. How did you attach the floor and walls to the steel frame? I was thinking 1 1/2 square tube with bolts. I would need to bore a larger hole in the bottom of the frame as to keep it flat on the bottom. I think my biggest issue will be the changing radius for the top, that's gonna be a challenge. I think I have got it figured out how to attach the camper steel frame to the steel truck bed and how to remove it so I can roll it into the shop when not in use but other things are yet to be solved. By the way the goal is to complete it by April 1st of next year and 3K max.
Rob
My '47 C.O.E build
Old 12-16-2016, 01:07 AM   #788
joedoh
joedoh's Avatar
iron bird! (also called a mock up) tape it out on the floor, then build all your stuff out of cardboard boxes.
the only problem I see with making it removable is that it will have to be self supporting, and that may add a whole ton of weight and bracing. why not make the thing sectional, so a two piece roof and it latches to the sides which also remove individually? it gets its assembled strength from the attachments and doesnt need lifted.
just spitballing
Old 12-16-2016, 07:51 PM   #789
lower50's
lower50's's Avatar
I could take a pic but this is prob better. Hope this helps. If I ever build another I am doing it the same.
1951 MG TD
Old 12-17-2016, 05:29 PM   #790
47 Fasttoys
Got started on the frame for the camper today. I started by making a a rectangle frame out of 1 1/2" square tubing. To that I added 1 1/2 X 2", 1/4" angle iron for cross bracing. With the 1/4" I will later be able to drill and tap to attach the flooring. The frame should go in the 250-300# range when complete. The angle pieces where used to keep it square while welding. It should end up even with the rear of the bed but hang over on the sides just a touch. More floor supports will go on, ran out of steel.
Rob
My '47 C.O.E build
Old 01-02-2017, 10:12 PM   #791
47 Fasttoys
OK, so i'm taking some small steps in the camper project. I picked a square tubing roller and modified the truck to haul 20 foot sticks of tubing. The idea being I don't need to have them cut just to get them home. One plus of having a steel bed is I can weld on it and just grind it back off later
Rob
My '47 C.O.E build
Old 01-02-2017, 11:38 PM   #792
Coldshot
Coldshot's Avatar
Love the camper idea. This is a project I'd love to do. I've always thought of using aluminum square tubing and bolting it all together if I didn't have the proper welder in order to save weight.
Having that roller will make is super nice regardless of what you use tho.
Coldshot is offline   Reply With Quote
Old 01-03-2017, 07:17 PM   #793
Gokart Mozart
Check out homemade teardrop trailer forums. They're different but have the same systems you'll face. Might give you ideas too.
Have you thought of a leveling system that's attached to the truck or camper? Large stands like what pickup campers use.
Gokart Mozart is offline   Reply With Quote
Old 01-03-2017, 07:58 PM   #794
lower50's
lower50's's Avatar
Nice tool!!
Found this on FB
1951 MG TD
Old 01-03-2017, 09:39 PM   #795
47 Fasttoys
So you need to haul 20 foot sticks of steel tubing? got it covered. Started working on the walls today. Got the first basic frame shaped. First one wasn't bad, matching it will be a chore. Cool FB pick, Thank you.
Rob
My '47 C.O.E build
Old 01-03-2017, 10:11 PM   #796
Advanced Design
Now that is some impressive work with your tubing bender! Which one do you have?
Old 01-04-2017, 12:42 PM   #797
99 to Life
99 to Life's Avatar
great ideas and craftsmanship. I like the idea of hauling 20ft pieces.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-04-2017, 05:55 PM   #798
47 Fasttoys
It's a TR-40 model, Chinese made of course. Actually the quality looks to be pretty solid. Cost $300.
Rob
My '47 C.O.E build
Old 01-05-2017, 04:19 PM   #799
crestronwizard
Nice!
crestronwizard is offline   Reply With Quote
Old 01-06-2017, 11:37 AM   #800
joedoh
joedoh's Avatar
haha what a great way to haul steel.
