Old 12-13-2016, 02:38 PM   #26
66Submarine
66Submarine's Avatar
Re: Factory 327 engine
Paint on the main caps and they have been numbered with a punch...absolutely a rebuild. Grinding on the crank was not done by GM...
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 12-13-2016, 11:29 PM   #27
Classic v6 GMC's
Classic v6 GMC's's Avatar
Originally Posted by ryanv70c10 View Post
Factory small journal rods had 5/16" rod bolts. Those appear to be 3/8" from the pics. What size socket fits on the nut?
1/2 inch socket
Originally Posted by Brad54 View Post
Some of those pictures almost look like the crank counterweights were "knife-edged," which is an old racer's trick to reduce windage as the crank goes through oil.
It's a lot more crude in places than I've ever seen before, but it definitely looks like it.
That first series of pics also looks like material was missing from the side of the counterweight, like it was a void in the casting, or metal flaked off.
If it balances (which seems hard to believe), and isn't cracked, there's no reason not to run it.
-Brad
Just looked it up "knife-edged" and it does look similar on some of the counterweights.
If I decide to use it I will have it checked out.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 12-13-2016, 11:53 PM   #28
Classic v6 GMC's
The factory would not have painted the main caps or numbered them? This engine was in a low mileage truck and the heads had never been removed.
Maybe the engine had a vibration and they pulled the crank and tried to re-balance it?
I would not have thought GM would grind on a crank.
We have another original 327 we will take apart in a couple weeks. It will be interesting to compare the two.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-14-2016, 10:46 AM   #29
gabbin
gabbin's Avatar
I agree, they would have milled into the balance weights till it was even (true)
gabbin is offline   Reply With Quote
Old 12-14-2016, 11:39 AM   #30
60-66
60-66's Avatar
Been reading this thread , They DID paint the main caps and number them from the factory , those are assembly paint inspection markings to signify the steps were done and checked. I have a brand new NOS 327 crank I will dig out , some of the cranks even had paint markings as did rods. Perhaps Keith Seymore could explain it better. Also , this crank is NOT knife edged , that was done only in extreme racing situations and does not at all look like it was done here. I worked in an automotive machine shop for 20 years and ran the crank grinder in that shop everyday. Your crank is stock. The only explanation I can give here for the unusual looking milling is it was done to correct the balance . Clean it up , check everything, balance, clearance and re use it. If you bore the block you need to balance it anyway.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 12-14-2016, 02:04 PM   #31
Ken Magura
I too have been following this thread (very interesting).
I worked in a chevy dealership back in those days but that by no means makes me an expert.
I never knew of a 327 being in an original truck until 1966, but like I said , I could be wrong.
What is the date code on the block?
What numbers are on the stamping pad?
Just curious !!
Ken
Ken Magura is offline   Reply With Quote
Old 12-14-2016, 03:54 PM   #32
66Submarine
I'm talking about what looks like green overspray (also on the crank?) as if it was painted with the oil pan off. Maybe you're right...second set of pictures looks less like overspray.
Main caps numbered with a punch by hand from GM? I haven't seen that. And some of the bolt heads are also damaged (and maybe some rod bolt nuts flipped?).
IME the engines I've taken apart that had not been messed with did not look like this.
Why are we certain the heads haven't been off before? Steel shim gaskets? I just rebuilt two engines recently and used them on both.
I'm up for learning something, but I'll be surprised if this wasn't a rebuild of some sort.
Old 12-14-2016, 04:21 PM   #33
60-66
60-66's Avatar
Ken
Ken , this 327 was out of a c60 I believe , they were available c40-c60 in the earlier years.
Okay , I see that now, the green over spray, theres also a yellow inspection paint on the crankshaft , thats what " I thought" you meant , sorry. If that is over spray , you'd think you would see it elsewhere . Its on the side of the cap and on top but not on the bolt or any machined areas .
I didn't and don't see "punch marks" I see a number stamp , 2 , on the second main cap , that could be factory.
Old 12-14-2016, 04:36 PM   #34
60-66
60-66's Avatar
Heres some stamping's on the NOS 327 crank.
Old 12-14-2016, 10:48 PM   #35
Classic v6 GMC's
Thanks for the expert opinion. We are going to take our other 327 apart and if that crank looks better we will probably use it.
Just curious !!
Ken
The 327 was available in the c60's
The numbers on the pad are
F0310U
Looks like the same stamping's.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-15-2016, 11:12 AM   #36
60-66
60-66's Avatar
Heres another 327 crank with the first counter weight milled off similar to yours . Notice yours is drilled twice for balancing in the same area plus milled on that side. I really feel it was all done to correct the balance on that engine. The crudeness is unusual looking with the burnt look , possibly done with worn tooling at that moment or in haste.
Old 12-16-2016, 12:15 AM   #37
Brad54
Brad54's Avatar
Hey 60-66, just curious if those 327 cranks you have are large or small journal?
-Brad
(Sorry to hijack the thread)
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 12-16-2016, 12:21 AM   #38
60-66
60-66's Avatar
Hi Brad. Both shown are small journal . I do have a large journal also.
Old 12-16-2016, 08:01 PM   #39
Classic v6 GMC's
Thanks for the pictures. It does look similar.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-16-2016, 09:01 PM   #40
jayoldschool
Moderator
I feel bad for providing misinformation
jayoldschool is online now   Reply With Quote
Old 12-16-2016, 09:40 PM   #41
Classic v6 GMC's
Don't feel bad. I created this thread to see what people thought about this crank. We are all learning here.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-16-2016, 11:13 PM   #42
66Submarine
I'm figuring the "2" on the main cap is a mark someone put there when they took it apart to mark it as the #2 main cap. Considering everything as a whole, I'd guess it's been apart before...just kind of looks like it IMO/IME. Pictures could be misleading, though.
As was said, pull some bearings and see if they are original...I'm curious.
Old 12-17-2016, 12:01 AM   #43
Classic v6 GMC's
I will pull the bearings this weekend and post some pics.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-17-2016, 10:37 PM   #44
Ken Magura
I learned something from this thread about the 327 truck engines being installed in the larger trucks before 1966.
(never too old to learn !!)
Thanks everyone
Ken
Old 12-18-2016, 03:41 AM   #45
'63GENIII
'63GENIII's Avatar
Were there ever any cast 327 cranks made in either large or small journal? Ive had several 327s years ago and can't recall any having other than a forged crank.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 12-18-2016, 09:35 AM   #46
Bernie M
Pretty sure 67 and older were small journal forged, 68 and up not steel they were cast. Large journal , I know in the cars for sure. Trucks?
Bernie M is offline   Reply With Quote
Old 12-18-2016, 11:40 AM   #47
60-66
60-66's Avatar
1962-1967 Car are small journal 327s . 1967 truck started the use of a large journal crank, usually forged and cars had the cast version from 1968 1969. 1967 Camaros with a 350 had a large journal crank also.
Old 12-18-2016, 01:01 PM   #48
jayoldschool
Moderator
So my 65 Impala 327 is small journal forged, correct?
Old 12-18-2016, 02:00 PM   #49
ryanv70c10
All small journal 327 cranks were forged. Most large journal 327 cranks were cast. The hi po 327 large journal cranks were still forged. I had one a few years back in my Nova.
ryanv70c10 is offline   Reply With Quote
