Old 12-13-2016, 11:33 PM   #1
vht
Who has a BBC in their truck?
The 350 in my 84 I bought is pretty much wore out. Thought about a rebuild or even a 383 but can't spend that kind of money right now. I have a .030 over rebuilt 454 short block on my stand, along with a set of reworked 781 heads with 2.19, 1.88 SS valves and springs to match the Lunati hyd flat tappet cam I have. Engine has stock pistons, cam is a 550 lift street cam. I was planning on putting it in my 72 chevelle, but looks like the 434 sb will stay in it for now. Truck has 3.08's with a 700R, I would of thought it'd had at least 3.42's. Wish I hadn't bought the new 600 Holley now. The only other spare carb I have is a 830DP Holley. Also, I have a new set of headman 1 7/8 headers for my chevelle, anyone ever tried a chevelle header on a truck?
vht is offline   Reply With Quote
Old 12-14-2016, 12:12 AM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: Who has a BBC in their truck?
chevelle/camaro headers (early 70's) are all I run, never had an issue 2 or 4wd.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-14-2016, 08:10 AM   #3
Tiger Joe
cochino do you have any pics or part numbers of the headers you are running? Gonna need headers for our 79 and looking for options
Tiger Joe is offline   Reply With Quote
Old 12-14-2016, 09:36 PM   #4
meatwagon83
meatwagon83's Avatar
I have hedmann headers on mine, for a chevy pickup
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 12-17-2016, 01:03 AM   #5
77BBGMC
77BBGMC's Avatar
I have Hooker Super Comps 2455 for a Chevelle, 2" primaries / 3.5" collector, no issues on the passenger side, had to dimple a couple spots on the drivers side to clear the motor mount.
77BBGMC is offline   Reply With Quote
Old 12-17-2016, 11:00 AM   #6
I put some Headman "Elite ultra duty" thick flange headers on my 76 1 ton with a 454. Worked great, still work great.
Old 12-17-2016, 11:13 AM   #7
red406
Do chevelle/camaro headers work with column shift linkage?
red406 is offline   Reply With Quote
Old 12-17-2016, 11:38 AM   #8
b454rat
I had early chevelle ones on the 84 I built. Truck was a stick, and only issue I ran into was the hydro setup. I had to shim the slave out cause it hit a primary. I hate small blocks anymore. Once you drive a big block, you never want to go back!!!! The motor was nothing special, very similar to urs, stockish cam, same heads but stock valves. Truck had 35s, 4-speed, and 4.10s. It was like a sports car, just not the handling lol. I wouldn't recommend a 700, less you built it up. One of the many past trucks I've owned had a stock TBI454, 3.42s and 35s, it would lite the tires up coming out of a corner. Tried that with similar small blocks, and doesn't even come close. My current truck has a 200k 350, and it's killing me. I can't wait to put the 8.1 in!!!!
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-17-2016, 08:07 PM   #9
vht
Well, it looks like the 454 is going in mine. Been doing some body work and got some primer on it today. Had to pull it out to get some customers cars in, so I took it up the road. It is one sick puppy. I got a guy that does all my automatic trans rebuilds, He said he could do the 700 for $650. Never had 1 problem from any of his transmissions, but he has done them all his life. I'm kinda considering a beefed 350 turbo though. Whats the adapter cost so I can keep my current driveshafts? Found some on ebay but don't know if they're the right ones. The BB will be putting out a lot of torque and around 425 to 450 HP, so that 700 is going to be tested pretty good, plus the 3.08 gears and 11.50's thats on it, I won't take advantage of the OD around here.
Old 12-17-2016, 09:20 PM   #10
vht
Also which 350, short or 9 inch tail housing. I got to find a core. Got a rebuilt 400 for my 40 chev coupe project. Wish it would fit.
Old 12-31-2016, 09:10 AM   #11
halfgassed
I've had 2 700r4 454 trucks, one I was daily driving and plowing snow with.40 mile commute and plowed 4 winters before I smoked it but it was my fault for not setting the tv cable when I swapped out the Holley 900 injectsystem for a carb. The other was a 73 also with a warmed over 454/700/205. I loved that setup with the 410 rear. Just my opinion i'd build the 700.
halfgassed is offline   Reply With Quote
