12-18-2016, 05:02 PM | #1 |
350 engine
Hi folks:
Yesterday I bougth a supposed 350 engine,I hope it is 350, I found this engine was madr in Mexico. Posted via Mobile Device |
12-18-2016, 05:05 PM | #2 | |
12-18-2016, 05:29 PM | #3 |
Re: 350 engine
Prob. a crate engine....the 260 hp & 290 hp 350 engines & possibly others are Mexican blocks. No worries...they are good engines....many have put lots of miles on them with good results.
12-18-2016, 05:38 PM | #4 |
Re: 350 engine
Most likely go crate engine. All of those blocks are made in mexico. Look at 3 digit block casting in front of starter. Guessing it will be 880 casting.
12-18-2016, 05:52 PM | #5 |
Re: 350 engine
If it is a crate engine, have they always been 4-bolt blocks or was that only a more recent thing? Could very well have 4 bolt main caps.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
12-18-2016, 06:00 PM | #6 |
Re: 350 engine
Not all are 4 bolt blocks. Depends what part number and where it's built. I believe all the performance part builds are 4 bolt, the others are mixed.
Pull valve cover and look at that casting should tell you the story. Also there are crate short blocks from GM. We build a couple of those like 383HT. |
12-19-2016, 12:19 AM | #7 | |
12-19-2016, 12:25 AM | #8 |
Re: 350 engine
3970010 are usually 4 inch bore blocks, maybe always so it is likely a 350. That's a weird motor though, cast iron waterneck, 2 bbl. It is older syle though with the large VIN pad and the oil galley plug above the timing cover. Another weird thing is the heads don't appear to have a full set of accessory holes.
12-19-2016, 12:26 AM | #9 |
12-19-2016, 09:33 PM | #10 |
Re: 350 engine
Is that a 350 damper/balancer ? It looks a little thin.
12-20-2016, 10:48 AM | #11 |
Active Member
Re: 350 engine
Re. why it looks different. Seems like the previous owner bought a short block and used the parts of his older engine.
The intake almost looks like the one I took off my old '69 Chevy truck.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
12-20-2016, 04:13 PM | #12 |
Re: 350 engine
Yeah. #3970010 + mexico = 350 block. Date code should be on the bell housing flange as well. Though one can never be sure with Mexican castings.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
12-21-2016, 04:11 PM | #13 |
Re: 350 engine
Thanks folks for all of your opinions. I will now if is really 350 as soon as I open it, I wiil keep this thread, I hope the engine is in condition to be rebuilt it, if is, I will need your help with your suggestions on how to make it strong.
Thank you again |
12-22-2016, 04:05 AM | #14 |
Re: 350 engine
Suggestion for making it strong... push it to the curb and buy a new crate engine
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
12-22-2016, 06:39 AM | #15 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: 350 engine
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
12-22-2016, 08:51 AM | #16 |
Re: 350 engine
I would not push it to the side if you are looking for performance . Being you have the block and it checks out I would consider a 383 stroke kit . For what you want to do you could get a 383 stroke kit for around 800.00 . Have the machine work done and assembled for around 300.00 to 400.00 . Less if you decide to assemble yourself . This would give you options for a much better head if wanted (cam also ) . If you will be satisfied with 200hp by all means get the crate motor . If you buy the crate motor and decide to mod for more power later you will spend a good bit more than the 1500.00 and not get close to the 383 potential . So I guess it boils down to where you want to go when you say performance . Performance has a pretty broad meaning .
12-22-2016, 10:50 AM | #17 |
Re: 350 engine
Yes!!!!!! HOMEMADE
that's exactly what I want, performance your suggestion of 383 sounds good. That's why I want to take all of the time to hear your counseling Thanks |
12-24-2016, 07:33 PM | #18 | |
Active Member
Re: 350 engine
Also, keep track of every bolt and place groups of parts like rockers, rods and springs together. I use plastic freezer bags and write on them what the bolts are for and unless you have a photographic memory take pics.
12-25-2016, 06:23 PM | #19 |
Re: 350 engine
its a target master motor built in mexico and it is very good 3970010 number block 4 bolt main 76cc heads 8.5 to compression. 450 lift cam if I remember correctly. brand new it was $750.00 bucks back when they came out. 1976 I think.
12-26-2016, 02:54 PM | #20 |
Re: 350 engine
Well, no way to be certain it is a 4-bolt main without pulling the to pan look. And I never was a big fan of Target Master engines. Most every one I received had factory rejected parts. Got a whole run of 350s from fleet service with misaligned cam journals repaired with offset spacers. Mexican castings were the worst.
