Old 12-21-2016, 11:06 AM   #551
UKNOWME
UKNOWME's Avatar
Re: 85 GMC Sierra "Scarlett"
Originally Posted by N2TRUX View Post
Keep in mind retro is coming back strong right now, hence the directional styles.
Touche
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 12-21-2016, 01:36 PM   #552
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I vote 5 spoke as well. It will look great regardless.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 12-21-2016, 01:57 PM   #553
daddyjeep
daddyjeep's Avatar
I'm leaning this way myself. I had to see it so I did a quick photoshop. If you painted the lip of the wheel to match the champagne color it would be even better.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 12-21-2016, 02:24 PM   #554
LT7A
Good job DJ with the foto shop. I wondered the same thing about bringing the gold tone onto the barrel of the red wheel. Maybe in tone only, more subtle than an exact match? As for my opinion, I'll defer since I don't know if that was an implied request for opinions, since it wasn't stated as such.
Old 12-22-2016, 12:20 PM   #555
N2TRUX
Happy to be here
N2TRUX's Avatar
I appreciate everyone input and the photoshop. I will announce what my choice is on Monday after Christmas. Meanwhile go to American Racings Instagram feed and follow them. They have a pic of Scarlett and an offer for a free shirt and hat for the first person to guess which wheel I will be running.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
"Refining Sierra"
Old 12-22-2016, 08:27 PM   #556
85supersierra
85supersierra's Avatar
I like the directional wheel but not sure if it would look right on a square. I know the cost would be ridiculous but it would be nice if you could get directional wheels in both directions. It always annoyed me to see the passenger side turning backwards.
85supersierra is offline   Reply With Quote
Old 12-22-2016, 09:00 PM   #557
lolife99
67-72 parts collector,…
lolife99's Avatar
Most Billet directional wheels are sold as left and right side wheels.
Only the cheaper version only come in one direction.
Keith
Convert to disc brakes.
Old 12-22-2016, 11:51 PM   #558
N2TRUX
Happy to be here
N2TRUX's Avatar
Countdown to Throwdown! Tonight I worked on installing the door panels we had previously restored. Chris had already located matching screws so I installed the belt line trim from Precision Replacement Parts. The new trim fits so much better than the flimsy pieces being replaced.
Articles-
"Refining Sierra"
Old 12-23-2016, 09:35 AM   #559
mcbassin
Still Learning
mcbassin's Avatar
I like the 5 spoke style with these trucks. My guess is you'll pick the VF-506 as your choice too. Nice work on the doors too.
You are getting close on the interior
Old 12-23-2016, 11:09 AM   #560
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by mcbassin View Post
.... Nice work on the doors too.
As always its three steps forward and two steps back. I held the original lower panels up to the door last night and decided they had to go. I will be order a set that actually matches the carpet kit.
Since I finally had the majority of the interior back together with the new Precision Replacement Parts seals and vents I wanted to test out the quietness of the cab to see how much of an improvement the Silent Coat deadner had provided. I rolled up the windows and shut the doors tight. They had a nice solid thud when slammed shut with no rattles. I started the motor and let it settle to an idle. I revved it a few times and could definitely notice a big reduction in the exhaust sound.
Pleased with the results I decided to call it a night. I reached for the shiny new door handle and gave it a pull. The smooth as silk action resulted in nothing. Apparently I knocked the rod off of the door handle mechanism and now I get to take the door panel off once more. Despite that, I still love the results of our interior rebuild.
Articles-
"Refining Sierra"
Old 12-23-2016, 10:37 PM   #561
N2TRUX
Happy to be here
N2TRUX's Avatar
Tonight was a lesson in frustration that ended in failure. I pulled the door panel and noted that the clip that hold the actuator rod on the door handle didn't get installed when the new handle went on. I had ordered the correct clips just forgot to install it. No big deal, just install the clip and reassembled the panel.
The panel fought me but I got it on and the handle worked. I rolled the window up and it jumped from its track. WTF? I rolled it up and down several times last night and it was super smooth.
I pulled everything apart and can not determine whats wrong. I spent 2 hours trying to analyze what's wrong and I'm perplexed. I decided to call it a night and look at it tomorrow.
Articles-
"Refining Sierra"
Old 12-24-2016, 02:28 AM   #562
rustytruck50
rustytruck50's Avatar
Sounds like a worn roller, letting it jump out of the track or the regulator might have gotten slightly bent or twisted. You might also check to see if the ends of the slide where the roller is located because I have seen the crimped ends get pushed out, letting the roller slide right out the end....just a thought.
One more place to check is the felt run channel that goes lower into the door...sometimes those get pulled out at the bottom and create all kinds of agravation.
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 12-24-2016, 11:27 AM   #563
N2TRUX
Happy to be here
N2TRUX's Avatar
I have examined the rollers as best as possible. It appears the front one has a slight bit more slack than the rear one but it's not much. Unfortunately I don't know how to tell if it's the problem.
What throws me off is it worked just fine before I pulled the panel. I tested it several times and it worked perfectly. All I did was pull the panel to put the linkage clip on the handle then reinstalled the panel.
Articles-
"Refining Sierra"
Old 12-24-2016, 12:51 PM   #564
rustytruck50
If you have a caliper set or just a ruler, see if you can compare the size of the rollers....the front one may be worn just enough to jump out with the torque of the motor. If you haven't already done this, you could run the window up & down a few times with the door panel off and see if you can find anything out of the ordinary when the rollers move in the slides. I have seen too much grease on those nylon rollers be as bad as not enough...that grease has a real tendency of breaking down the nylon over the years.
-Doug
'05 RCSB Sierra 2WD
Old 12-24-2016, 10:08 PM   #565
N2TRUX
Happy to be here
N2TRUX's Avatar
I have viewed it as best as possible and don't see anything unusual. I plan to try it again after Christmas when I have an extra set of eyes and hands to help me scrutinize. I hate to pull the other door panel again to compare, but that's next on my list. I'll report back when I get back to it.
Articles-
"Refining Sierra"
Old 12-24-2016, 10:21 PM   #566
N2TRUX
Happy to be here
N2TRUX's Avatar
Today I had to work on my wife's remodel project. She is converting my daughters room from teenage to married couples room. That means all new furniture and the powder blue had to go. I now know what color perfect taupe is.
With that done I went to the shop for some truck therapy. Since my power window predicament has me stumped for the moment I decided to focus on moving forward with the under hood transformation.
Chris and I determined that ring to work over the bumper like last time was not good so I removed the grill and bumper. I masked the edges and plan to add some protection for the fender as they will stay on.
Here's where I got before stopping to go wrap Christmas presents. Merry Christmas ya'll
Articles-
"Refining Sierra"
Old 12-24-2016, 11:09 PM   #567
rustytruck50
Merry Christmas and hopefully you don't have visions of taupe color chips dancing in your head tonight!
BTW...your skill, tenacity & patience will overcome this bump in the road!
-Doug
'05 RCSB Sierra 2WD
Old 12-25-2016, 10:48 AM   #568
N2TRUX
Happy to be here
N2TRUX's Avatar
Patience not so much, persistence allows me to persevere.
Merry Christmas to you and yours.
Articles-
"Refining Sierra"
Old 12-26-2016, 09:47 PM   #569
N2TRUX
Happy to be here
N2TRUX's Avatar
Countdown to Throwdown! I made my final decision on which @americanracing wheels would best fit the personality of this build. The #VF506 has a clean and classy look that flows well. Thanks to everyone especially @cplump71 of @americanracing for your input.
Articles-
"Refining Sierra"
Old 12-26-2016, 10:03 PM   #570
N2TRUX
Happy to be here
N2TRUX's Avatar
I decided to diagnose the oil drip coming from the rear of the motor. I knew the oil pan gasket was seeping and suspected the rear main seal was too.
I also wanted to determine for I had a one or two piece rear seal. Research showed that passenger side dipstick should mean one piece and I verified that to be true.
After removing the transmission dust cover I noted what was oily and what wasn't. The center of the flywheel was dry and dusty telling me the leak was coming from another source. I feel comfortable that the oil pan is the source. Fortunately a pan gasket isn't hard to change on a C10.
I also noted that the transmission had a date and initials stamped in it verifying that it had a fresh build and could see the torque converter was fresh too.
Articles-
"Refining Sierra"
Old 12-26-2016, 10:11 PM   #571
N2TRUX
Happy to be here
N2TRUX's Avatar
While waiting for the oil to drain I worked on the drivers side. I pulled the fender liner to gain access to the mess I need to clean up. I have some serious detail work ahead.
Articles-
"Refining Sierra"
Old 12-26-2016, 10:37 PM   #572
ultrahd4me
ultrahd4me's Avatar
Excellent choice on the wheels. Gonna be killer for sure.
Follow me on Instagram: @midtennc10
Youtube channel: Midtennc10
ultrahd4me is offline   Reply With Quote
Old 12-27-2016, 01:11 AM   #573
UKNOWME
UKNOWME's Avatar
Countdown to Throwdown! I made my final decision on which @americanracing would best fit the personality of this build. The #VF506 has a clean and classy look that flows well. Thanks to everyone especially @cplump71 of @americanracing for your input.
Sweeeeeeeeeet! I'm excited for you!
1964 Chevy c10
Old 12-28-2016, 12:56 PM   #574
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks guys. I considered several of American Racings styles, but the VF506 really seemed to fit the build. Lets see if I am right.
Articles-
"Refining Sierra"
Old 12-29-2016, 07:00 AM   #575
Desert1957
Desert1957's Avatar
OK, how much longer before the the new shoes?
Desert
Desert1957 is offline   Reply With Quote
