Old 12-24-2016, 05:40 PM   #1
Jmh68C10
Jmh68C10's Avatar
Looking for a Ls oil pan swap guide
Swapping a f-body oil pan on my ls3 for my swap. Don't know why I thought it the swap would be a little more straight forward but after researching some I've found that you need to have some alignment tools as the positions is critical. Does anyone have a link to a step by step with torque specs to complete this oil pan swap?
68 c10- Under construction
Jmh68C10 is offline   Reply With Quote
Old 12-24-2016, 07:12 PM   #2
KenAdams
KenAdams's Avatar
Re: Looking for a Ls oil pan swap guide
No alignment tools are necessary as long as you have a bell housing.
-Attach the oil pickup tube. 106in/lbs for bolts, 18ft/lbs for windage tray nuts
-Mount the bell housing to the block. 37ft/lbs
-Attach the oil pan to block hand tight, and oil pan to bell housing bolts slightly more than hand tight
-Torque rear M6 oil pan bolts to 106in/lbs
-Torque bell housing to oil pan bolts to 37ft/lbs
-Torque remaining M8 oil pan bolts to 18ft/lbs
KenAdams is offline   Reply With Quote
Old 12-25-2016, 12:18 AM   #3
Jmh68C10
Jmh68C10's Avatar
Thank you for the torque specs! Problem is the engine and trans are separated at the moment.
Old 12-25-2016, 01:43 AM   #4
ls1nova71
ls1nova71's Avatar
You really only need the alignment tools to install the front and rear covers. Since you are just changing the oil pan, all you have to do is put a straight edge on the back of the block and make sure the back of the oil pan is even with it. The reason it's critical is because the transmission bolts to both the engine block and oil pan, and if one sticks out further than the other, you run the risk of putting something in a bind when you tighten down the bolts. If you were running an older trans, like a 350 turbo or 700r4, then oil pan alignment wouldn't be a problem at all.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-25-2016, 08:15 AM   #5
NC_John
NC_John's Avatar
I read a design change/improvement in the front and rear covers make them a little less sensitive to their exact placement. I bought new ones for my LQ4 project so I hope that's true. I may also see if I can beg borrow or steal the alignement tools for assembly. An oil leak on my new engine would break my heart.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 12-27-2016, 10:56 PM   #6
Jmh68C10
Jmh68C10's Avatar
Two Questions
Do all ls engines have a factory riveted gasket ? If so this concerns me since the one that came off my L94 isn't riveted.
Am I correct by only running a small bead of Black RTV in the 4 corners gasket to block?
Old 12-29-2016, 03:33 AM   #7
spectral
spectral's Avatar
I believe factory was riveted, but aftermarket aren't, so its possible it is on its 2nd (or 3rd ) gasket already.
spectral is offline   Reply With Quote
