12-27-2016, 01:32 PM | #1 |
Lower arm setting
Wonder if it's important to set the lower arm in position with the notch and pin?
12-27-2016, 02:55 PM | #2 |
Re: Lower arm setting
Yes. Yes it is.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
12-27-2016, 03:04 PM | #3 |
12-27-2016, 03:16 PM | #4 |
Yes to all of the above. If and when it moves, it will affect your alignment.
How did you get it to seat without it going into the hole? Isn't there a gap now between the cup and u bolt?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
12-27-2016, 03:39 PM | #5 |
That's just the odd! I can't see any gaps! But I am sure that I missed it when I
mounting it in place. If I jack the lower arm and loose the bolts round the cup, do you think I can turn the support arm right? |
12-27-2016, 04:09 PM | #6 |
Probably... hopefully you installed them correctly, they are different L and R (notch and hole would be on opposite sides)
12-27-2016, 04:27 PM | #7 |
I missed that too!!! I think?
Thank you |
12-27-2016, 11:26 PM | #8 |
I'm lost as to what you mean here. Do you have any pictures to show exactly . I had to take my bottom arm off of the drivers side after it got damaged when the front wheel came off when all the wheel studs sheared
12-28-2016, 12:30 AM | #9 |
https://goo.gl/images/m3wUOF
Look at this link |
12-28-2016, 12:44 AM | #10 |
Who Changed This?
My antivirus software stopped me from looking at your link. Anyway-
If you got the lower control arm shaft to seat into the frame, that is one thing. But you need to make sure that the distance, as measured per the manual, is set correctly, or you will NEVER get the caster set correctly. You really need to either search the internet or get the service manual (recommended) so that you repair your truck properly, to avoid personal injury or property damage.
12-28-2016, 01:05 AM | #11 |
Sorry I don't follow "caster set"?
My English is limited, you know. Sad you couldn't open the link, it show how the support arm must be installed in the "cup" that hold the lower arm in position. |
12-28-2016, 01:06 AM | #12 |
12-28-2016, 03:16 AM | #13 |
Excellent many thanks Swed
12-28-2016, 02:12 PM | #14 |
This looks like an aftermarket tubular lower control arm in the picture. I can only tell you what I know based on the stock original control arms.
They need to be installed with the little "dent" or "hole" lined up properly with the nub or pin or whatever you want to call the part that seats into it. Even if you had it somehow in the perfect position, without the pin it would likely move around over time. So I think you need to verify it. If you do not have this correct your "wheel alignment", which is to say the direction the wheels are pointing, will never be stable. It will likely always change and drift and make the truck unsafe and no fun to drive. Or it might just all work out fine anyway, but if I were you I would want to know that it was done right. I'm afraid to tell you, but I think you should (safely!) take it apart again and check.
12-28-2016, 04:20 PM | #15 |
Have a look at this thread below. It has all the details you need including pictures...
http://67-72chevytrucks.com/vboard/s...masher+whacker -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
12-28-2016, 04:23 PM | #16 |
Some pictures from the thread:
12-28-2016, 05:34 PM | #17 |
the pin...
12-29-2016, 10:51 AM | #18 | |
12-29-2016, 10:53 AM | #19 |
12-29-2016, 10:57 AM | #20 | |
