12-21-2016, 11:06 AM | #551 |
Re: 85 GMC Sierra "Scarlett"
Touche
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
12-21-2016, 01:36 PM | #552 |
Junior Member
I vote 5 spoke as well. It will look great regardless.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
12-21-2016, 01:57 PM | #553 |
I'm leaning this way myself. I had to see it so I did a quick photoshop. If you painted the lip of the wheel to match the champagne color it would be even better.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
12-21-2016, 02:24 PM | #554 |
Good job DJ with the foto shop. I wondered the same thing about bringing the gold tone onto the barrel of the red wheel. Maybe in tone only, more subtle than an exact match? As for my opinion, I'll defer since I don't know if that was an implied request for opinions, since it wasn't stated as such.
12-22-2016, 12:20 PM | #555 |
Happy to be here
I appreciate everyone input and the photoshop. I will announce what my choice is on Monday after Christmas. Meanwhile go to American Racings Instagram feed and follow them. They have a pic of Scarlett and an offer for a free shirt and hat for the first person to guess which wheel I will be running.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-22-2016 at 12:26 PM. |
12-22-2016, 08:27 PM | #556 |
I like the directional wheel but not sure if it would look right on a square. I know the cost would be ridiculous but it would be nice if you could get directional wheels in both directions. It always annoyed me to see the passenger side turning backwards.
12-22-2016, 09:00 PM | #557 | |
67-72 parts collector,…
Only the cheaper version only come in one direction.
12-22-2016, 11:51 PM | #558 |
Happy to be here
Countdown to Throwdown! Tonight I worked on installing the door panels we had previously restored. Chris had already located matching screws so I installed the belt line trim from Precision Replacement Parts. The new trim fits so much better than the flimsy pieces being replaced.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-23-2016 at 10:55 AM. |
12-23-2016, 09:35 AM | #559 |
Still Learning
I like the 5 spoke style with these trucks. My guess is you'll pick the VF-506 as your choice too. Nice work on the doors too.
You are getting close on the interior |
12-23-2016, 11:09 AM | #560 | |
Happy to be here
Since I finally had the majority of the interior back together with the new Precision Replacement Parts seals and vents I wanted to test out the quietness of the cab to see how much of an improvement the Silent Coat deadner had provided. I rolled up the windows and shut the doors tight. They had a nice solid thud when slammed shut with no rattles. I started the motor and let it settle to an idle. I revved it a few times and could definitely notice a big reduction in the exhaust sound. Pleased with the results I decided to call it a night. I reached for the shiny new door handle and gave it a pull. The smooth as silk action resulted in nothing. Apparently I knocked the rod off of the door handle mechanism and now I get to take the door panel off once more. Despite that, I still love the results of our interior rebuild.
12-23-2016, 10:37 PM | #561 |
Happy to be here
Tonight was a lesson in frustration that ended in failure. I pulled the door panel and noted that the clip that hold the actuator rod on the door handle didn't get installed when the new handle went on. I had ordered the correct clips just forgot to install it. No big deal, just install the clip and reassembled the panel.
The panel fought me but I got it on and the handle worked. I rolled the window up and it jumped from its track. WTF? I rolled it up and down several times last night and it was super smooth. I pulled everything apart and can not determine whats wrong. I spent 2 hours trying to analyze what's wrong and I'm perplexed. I decided to call it a night and look at it tomorrow.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-26-2016 at 01:10 PM. |
12-24-2016, 02:28 AM | #562 |
Sounds like a worn roller, letting it jump out of the track or the regulator might have gotten slightly bent or twisted. You might also check to see if the ends of the slide where the roller is located because I have seen the crimped ends get pushed out, letting the roller slide right out the end....just a thought.
One more place to check is the felt run channel that goes lower into the door...sometimes those get pulled out at the bottom and create all kinds of agravation.
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold Last edited by rustytruck50; 12-24-2016 at 02:35 AM. |
12-24-2016, 11:27 AM | #563 | |
Happy to be here
What throws me off is it worked just fine before I pulled the panel. I tested it several times and it worked perfectly. All I did was pull the panel to put the linkage clip on the handle then reinstalled the panel.
12-24-2016, 12:51 PM | #564 |
If you have a caliper set or just a ruler, see if you can compare the size of the rollers....the front one may be worn just enough to jump out with the torque of the motor. If you haven't already done this, you could run the window up & down a few times with the door panel off and see if you can find anything out of the ordinary when the rollers move in the slides. I have seen too much grease on those nylon rollers be as bad as not enough...that grease has a real tendency of breaking down the nylon over the years.
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
12-24-2016, 10:08 PM | #565 | |
Happy to be here
12-24-2016, 10:21 PM | #566 |
Happy to be here
Today I had to work on my wife's remodel project. She is converting my daughters room from teenage to married couples room. That means all new furniture and the powder blue had to go. I now know what color perfect taupe is.
With that done I went to the shop for some truck therapy. Since my power window predicament has me stumped for the moment I decided to focus on moving forward with the under hood transformation. Chris and I determined that ring to work over the bumper like last time was not good so I removed the grill and bumper. I masked the edges and plan to add some protection for the fender as they will stay on. Here's where I got before stopping to go wrap Christmas presents. Merry Christmas ya'll
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-26-2016 at 10:33 AM. |
12-24-2016, 11:09 PM | #567 |
Merry Christmas and hopefully you don't have visions of taupe color chips dancing in your head tonight!
BTW...your skill, tenacity & patience will overcome this bump in the road!
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold Last edited by rustytruck50; 12-24-2016 at 11:15 PM. |
12-25-2016, 10:48 AM | #568 | |
Happy to be here
Merry Christmas to you and yours.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-26-2016 at 10:34 AM. |
12-26-2016, 09:47 PM | #569 |
Happy to be here
Countdown to Throwdown! I made my final decision on which @americanracing wheels would best fit the personality of this build. The #VF506 has a clean and classy look that flows well. Thanks to everyone especially @cplump71 of @americanracing for your input.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-27-2016 at 10:37 AM. |
12-26-2016, 10:03 PM | #570 |
Happy to be here
I decided to diagnose the oil drip coming from the rear of the motor. I knew the oil pan gasket was seeping and suspected the rear main seal was too.
I also wanted to determine for I had a one or two piece rear seal. Research showed that passenger side dipstick should mean one piece and I verified that to be true. After removing the transmission dust cover I noted what was oily and what wasn't. The center of the flywheel was dry and dusty telling me the leak was coming from another source. I feel comfortable that the oil pan is the source. Fortunately a pan gasket isn't hard to change on a C10. I also noted that the transmission had a date and initials stamped in it verifying that it had a fresh build and could see the torque converter was fresh too.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-27-2016 at 10:39 AM. |
12-26-2016, 10:11 PM | #571 |
Happy to be here
While waiting for the oil to drain I worked on the drivers side. I pulled the fender liner to gain access to the mess I need to clean up. I have some serious detail work ahead.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-27-2016 at 10:41 AM. |
12-26-2016, 10:37 PM | #572 |
Excellent choice on the wheels. Gonna be killer for sure.
Follow me on Instagram: @midtennc10 Youtube channel: Midtennc10 |
12-27-2016, 01:11 AM | #573 |
Sweeeeeeeeeet! I'm excited for you!
12-28-2016, 12:56 PM | #574 |
Happy to be here
Thanks guys. I considered several of American Racings styles, but the VF506 really seemed to fit the build. Lets see if I am right.
12-29-2016, 07:00 AM | #575 |
OK, how much longer before the the new shoes?
Desert |
