10-14-2016, 09:03 PM | #526 |
Re: Bringing the '65 back to life
10-15-2016, 02:10 PM | #527 |
Not a big fan of doing things twice, particularly when it involves gear lube. :/ Turns out that some of the diff cover bolt holes weren't drilled/tapped deep enough back in '65 to accommodate the bolts that came with the LPW cover, which caused a leak. Pulled the cover, cleaned everything, and reinstalled it today with shorter bolts, then spent the rest of the day working on other projects in the shop.
10-16-2016, 02:54 PM | #528 |
10-23-2016, 05:16 PM | #529 |
10-29-2016, 07:50 PM | #530 |
11-05-2016, 04:29 PM | #531 |
11-13-2016, 06:57 PM | #532 |
11-19-2016, 07:07 PM | #533 |
Repaired a bunch of rust on the grill support today. Actually thought I was finished, then found a bit more which I'll save for another day.
One tip to anyone out there tackling a rust repair project like this: take the few extra minutes to properly fit your patch panels. The better the fit, the better the end result. |
11-20-2016, 06:20 AM | #534 |
Nice repair.
11-21-2016, 05:56 PM | #535 |
Thanks. I never remember to take any step by step photos like that to show before/during/after.
Finished up the grill support this morning, then began fitting up the rear bumper. The brackets needed a little mill time to get everything to line up correctly. Once the filler panels and license plate bracket arrive, and everything gets painted, we'll be able to do the final install. |
11-22-2016, 09:20 PM | #536 |
Threw a coat of primer on the bumper brackets this morning, then turned my attention to building an instrument cluster. We've decided to ditch the factory cluster for more accurate instrumentation, and I'm not a fan of the typical gauge mounting plate that bolts to the bezel, as that points the gauges directly at the driver's chest. More to come on this instrument cluster design, provided it turns out.
11-25-2016, 03:39 PM | #537 |
Continued working on the instrument cluster today. Whipped up a wood buck to shape the housing around, then cut a strip of sheetmetal out of an old bedside from my F150. After a little shaping, it fit the frame perfectly. The little tabs on the frame weld to the housing to lock it together while keeping the welds out of sight. Next, I'll need to cut the overlap out of the housing, weld the seam, weld the last few tabs, then bolt it into the truck to determine the angle for the back panel.
11-26-2016, 02:47 PM | #538 |
The instrument cluster is far enough along that it's time to stick it in the dash and determine the angle for the back panel. The old lens is just a placekeeper; the final instrument cluster lens will be a clear pane.
We also installed the rear bumper today. It's a used chrome bumper that definitely needs a good cleaning, but it'll do for now. We can drop the coin on new chrome bumpers in the future. |
12-03-2016, 05:33 PM | #539 |
12-05-2016, 10:30 AM | #540 |
I'm just glad to be here!
Nice work!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
12-19-2016, 09:19 PM | #541 |
12-20-2016, 08:20 PM | #542 |
12-21-2016, 06:17 PM | #543 |
12-21-2016, 10:53 PM | #544 |
Good news. There's a lot left on the table in the stock tune, even running plain old 87 octane.
12-22-2016, 05:43 PM | #545 |
The saga of fitting repop parts continues.
Top left and right photos: Dad had the honors of climbing into the engine bay to drill the spot welds out of the driverside inner fender bracket. It was attached to the inner fender ~1" above the correct location (verified both by fitment and by comparing to the passenger side inner fender from the same source). It will get a little tweak before being properly located and welded in place. Bottom left: Put it together, mark what doesn't fit correctly, take it apart, fix it, and try again. Time consuming work. Bottom right: Without sectioning the fender or stretching the grill support, that's as good as it's going to get on this side. The fender is physically a "smidge" taller than the grill support. |
12-23-2016, 04:50 PM | #546 |
12-26-2016, 06:51 PM | #547 |
Dad got a fuel system for Christmas yesterday: a 18 gallon, fully baffled cell with a sump for an in-tank pump, along with a 400-lph Walbro pump, sending unit, etc. After we finished a few small tasks on the front clip and tidied up the shop, we did a quick test-fit in the 60" chest-style toolbox that will soon reside in the bed. The box will hold the fuel tank, battery, a fire extinguisher, and function as a lockable trunk.
12-27-2016, 05:57 PM | #548 |
12-28-2016, 07:59 PM | #549 |
12-28-2016, 08:06 PM | #550 |
Happy operating!!!
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
