#1401 |
![]() Join Date: Jul 2012
Re: 48 Burb, bagged, 5.3, 20 year wait
The solution for the contact between the pinion stub shaft U-joint and the cross member is to notch the cross member with a pipe notch. Cut out here, it will be finished when I take the powertrain out again.
Steering almost worked with only two u-joints though it needed three to clear the frame and exhaust header. I still need to do the stake procedure per Borgenson directions and this part is done. Their parts are pricey and worth it...don't cheap out on steering. Next up is mounting the brake pedal assembly bracket...marked out here from fitting. Decided to take a look at that again tomorrow to verify accuracy before drilling holes in the firewall. Really don't want to do that wrong.... ![]() Oh, check out the light my new Snap On LED puts out. Wow, under dash is now as bright as shop floor. And the light isn't hot. |
#1402 |
![]() Join Date: Mar 2007
Steering looks great Doug. I need to get the LS mock up block back to confirm my set up clears the headers...It's nice having functional steering when pushing the truck around. Since I swapped the 20's up front I was able to hook up my steering rack links.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#1403 |
![]() Join Date: Aug 2012
You aren't kidding about those lights. I bought a pair at Costco a while back. Just like you said, bright but not hot. That was a big win with me as i have a ton of little ones running around.
So who's going to end up with the sweeter 'burb? You or youngrodder? ![]() Right now, its neck and neck. I realize it's not a competition, but nice. Last edited by iowaboynca; 12-29-2016 at 12:27 AM. |
#1404 |
Steering looks good Doug!! Wish mine was that "easy"....
I've got a small version of that worklight, I find them really nice to work with.
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#1405 |
very clean looking
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#1406 |
![]() Join Date: May 2007
haha nice light, I got rechargeable LED shop lights for christmas so no more knocking around that old (and hot) drop light
column looks great, nice install pics! I have a question about the upper arms, I see the slots are in the direction of force of the arms, do they ever loosen (or even not loosen) and go out of alignment?
#1407 | ||||
Thanks 99! Looking forward to your engine updates and TCI install. Quote:
The slots in the upper arms are styled after the original 74 - 78 Mustang II using T bolts (serrated on bottom) to clamp the arm in place. Cater and camber obviously adjusted by loosening the T bolt and sliding. They work OK I guess as there are many out there. One came loose on my black truck once.. ---------------------------------------------------------------------------------------- Brake pedal assembly, booster and master cylinder are in place. The hardest hole to drill in that new firewall was the first one. Really took my time in measuring, marking and verifying and they came out dead on. Made a little support for the end of the brake pedal assembly to tie it into the diagonal brace under the dash. Wow, I had fabricators block on that one as I stared at it and fumbled around with various ideas for 2 hours. I think the downward force of a brake apply is now spread evenly across the back of the brace. Those little switch on magnets are really handy! Was it 99 using them last year and I ordered some? The cross piece on top of the brace is welded solid across the back. Front side has three short welds. Now to get the brake push rod length adjusted for the booster and master cylinder. Thanks again to Mark - Reaper71- for the lead on this brake assembly from Speedway. Booster came from Summit and Wilwood from my friend Mike at Rutters Rod Shop. |
#1408 |
Fun putting shiny new parts together....even if only for test fitting.
#1409 |
![]() Join Date: Mar 2011
Doug, should have no problem with the brace. Pedal looks good. Have a happy New Year...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#1410 |
Came out nice Doug just like you planned!
![]() Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#1411 |
Looks great Doug. The dashes are pretty flimsy. I know mine could benefit from an additional brace and that's even with my brakes being a frame mount.
Nice looking booster.. Marc
#1412 |
Thanks Jim, Mark and Marc.
Last update of the year... Fabbed up and installed the fuel fill pipe support today. Happy New Year to my internet friends! |
#1413 |
You know that's cheating using that lift don't ya??? That modification would be more satisfying laying on your back under the suburban...
Happy New Year Doug Marc
#1414 |
Very nice build. wish I had some of you ability. Really like the build. hope some day to have a Burb to match the truck.
1950 3100 5 window |
#1415 | |
I love those little switch magnets, just the right size for lots of stuff. I used one to hold the door open on my 41 tonight! ![]()
#1416 |
Happy New Year Doug to you and yours..
Mark..
#1417 | |||
Happy New Year Mark! |
#1418 |
Happy new year!! I have a brace from my fire wall to the dash and I see no flex. Yours looks much nicer tho
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#1419 |
Happy new year Doug and your family!!
Nice and simple support for the fuelpipe. I also made my own bracket between firewall and dash, I have no flex. Already had to make an emergencystop at 30mph, all is still in one piece ![]() ![]() I'm with Lower, yours look plenty strong!!
#1420 | |
Scott ______________ my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979 |
#1421 |
Doug;
![]() Have posted new pic on the panel project; Al so posted New pic in the Alternate Tinkering post. T-P Auto ![]() Tim |
#1422 |
The Burb is looking great Doug. The pedals and steering aren't the funnest part of the project but definitely necessary. Your install on each looks great.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=654899 |
#1423 |
Thanks guys! Dave, appreciate your positive comments, you do such awesome work! Apologies for lack of Burb progress....we've been busy with many other projects, adventures and duties it seems this year. Shop Ceiling repair and paint, gator engine, lawn mower stuff, funerals, family, yard projects. Basically life ...
We are in the middle of Long Haul on Hot Rod Power tour right now. What a blast! St. Louis, Indianapolis and Bowling Green left to go. So, we plan to be back on this Burb soon. Thanks for hanging in there with us. |
#1424 |
Welcome back!
Yeah, life has a tendency to do that. Have fun on the tour. We want pics! |
#1425 |
Have fun on the tour! I wish I was running alongside of you.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
