12-29-2016, 09:33 AM | #1 |
In a tight spot
Need some help........
Any recommendations on the best headers to use on LS2 with rack and pinion steering? Using a 3 knuckle steering setup. The DD shaft will need to run between the header tubes and the inside of the frame. Installed Hedman's with 1-3/4 diameter mid-length tubes. These do not provide enough room for the DD shaft to pass. Has anyone experienced this issue?
The Glueman ________________________ 1967 C10 Shop Truck 1967 Nova 1968 C10 1972 Blazer |
12-29-2016, 11:02 AM | #2 | |
The Older Generation
Re: In a tight spot
I used these on my '67 Chevy Panel Truck and they have quite a bit of header to frame clearance. I can measure the distance if you want me to.... http://www.ebay.com/itm/Hooker-Heade...xTxRxO&vxp=mtr LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-29-2016 at 11:19 AM. |
12-29-2016, 11:07 AM | #3 |
Re: In a tight spot
2010+ Camaro manifold work really well.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
