Old 03-27-2004, 11:35 PM   #1
proboner
flushing the coolant system?
my coolant system is TRASHED, its got all kinds of crap built up in it. can anyone suggest a method for flushing it, and a chemical or something that can take care of all the sludge without ruining seals and whatnot?
1993 ford probe gt- 15.2@90.7
http://www.cardomain.com/id/pr0b0ner
1969 chevy c10 pickup- bought for $100 at an impound lot... always wanted a 1972 blazer cst, but this will do for now!
proboner is offline   Reply With Quote
Old 03-27-2004, 11:59 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
You may want to take the radiator to the shop and have it rodded
as for as the rest of the system take a garden hose and flush the system by filling and removing the lower hose several times.
sneakysnake is offline   Reply With Quote
Old 03-28-2004, 05:01 AM   #3
Southpa
Southpa's Avatar
I cut the upper hose going to the heater core and install a plastic TEE fitting made for this very purpose (available at autoparts, hardware, etc. stores). Your garden hose then screws onto that. Then undo the lower rad hose for an outlet and turn on the water. When you are done just screw the cap on the TEE fitting.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 03-28-2004, 07:57 AM   #4
jef5150
Inline 69
jef5150's Avatar
it looks like your heater core is is being bypassed, more than likely p/o did this cause it leaks. i would hook up the hoses to the heater core to make sure the heater core is ok first , then back flush the system.If the radiator is as bad as you say, the heater core is gonna be in the same shape. jeff
jef5150 is offline   Reply With Quote
Old 03-28-2004, 12:18 PM   #5
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
I agree with the back flushing. I rodded out my own radiator. A propane torch, a little wire brush, 1/8in rod stock and a roll of soder is all that is needed. The radiator flushes that you can buy at the parts store is junk.
67Fleetsidedream is offline   Reply With Quote
Old 03-28-2004, 04:15 PM   #6
proboner
alright ive got an idea of my own, tell me how stupid you think it is... ill bypass the heater core (which appearantly is already done) bypass the radiator, and just turn the beast on and run it until it warms up. hopefully having some hot water running thru it will clean all that crap off. ill do that a few times changing the water in between cycles. while im doing that ill take the radiator out and pour some kind of chemical (carb cleaner? seems to kill everything else?) in there and mix it up real nice in an attempt to get anything out of there. once im all done ill install a new water pump and reconnect everything and hopefully all will be well. so this is the part where you all tell me im a moron.
Old 03-28-2004, 04:33 PM   #7
67Fleetsidedream
MORON!!!!!!!
:p
Old 03-28-2004, 05:00 PM   #8
cableguy0
buy a new radiator take a garden hose with a cut off end and clamp it to one of the heater hose ports on the motor
turn the hose on let it run till the water comes out clear. put on your new radiator and heater core. no more problems
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
