Old 12-29-2016, 10:31 PM   #1
coleman64
wiper problems
1990 chevy crew cab I at one point swapped steering column for tilt column, wiper delay has never worked since ive owned it, ive switched delay module units and motor from another vehicle still nothing. wipers have manual trip and low and high all work but no delay. what is wrong and what can i do to test it. Iv tested the connectors at the motor and they have power. Main question is what connectors on the motor actually power it and.
coleman64 is offline   Reply With Quote
Old 12-29-2016, 11:21 PM   #2
cooter26
cooter26's Avatar
Re: wiper problems
WINDSHIELD WIPER DELAY CIRCUIT The wiper delay control circuit is an option on R/V and P models. This option allows the wiper to operate at a slower rate than the low speed setting on the standard control. The delay module is inserted into the harness under the steering column (figure 5). For delay circuit diagnosis, refer to figure 14.
Cant cut the diagrams out of the manual but there is a module strapped to the column bracket on the left side. The trouble shooting diagram says if all the other functions but delay work, check module connections, if they are ok check
resistance on steering harness connector BRN to BRN 0-50 min 500k max. Resistance ok replace module, resistance not ok replace wiper switch.
Corey
1991 V3500
cooter26 is offline   Reply With Quote
Old 12-29-2016, 11:31 PM   #3
coleman64
Re: wiper problems
is there any way to test if there is power being delayed at the motor? at like the connectors at the motor.
Old 12-29-2016, 11:53 PM   #4
ray_mcavoy
Re: wiper problems
No ... power isn't delayed at the motor. Instead, the motor has a constant power feed (live whenever the ignition is on). The switch (and delay module) are on the ground side of the circuit. They complete the connection to ground to run the motor or open up the connection to stop the motor.
ray_mcavoy is offline   Reply With Quote
Old 12-29-2016, 11:54 PM   #5
cooter26
cooter26's Avatar
Re: wiper problems
Name:  wiper motor.jpg
Corey
1991 V3500
Old 12-30-2016, 12:02 AM   #6
hatzie
Moderator
hatzie's Avatar
Re: wiper problems
The wiper motor has ignition power at all times. The delay is a pulsed ground. You could watch the signal on the LO wire with a scope. That's not going to tell you much when nothing is happening.
Or you could do it the easy way like the service manual outlines...
I would unplug the column connector and test the resistance of the potentiometer in the column switch.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
