Old 01-01-2017, 01:55 PM   #1
ratfreak8871
I'll try this again....
Hello all, happy new year. I have a 79 swb 2wd half ton. It has a 2 piece drive shaft as far as I can tell its factory. Ever heard of such a thing? My problem is I cant switch to a 1 piece bc my th400 has the bolt on yoke. so I'm stuck with a 2pc????
ratfreak8871 is offline   Reply With Quote
Old 01-01-2017, 02:23 PM   #2
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Re: I'll try this again....
Happy new year! Long beds with a 400 (bolt on yoke) came with 2 piece drive shaft with a carrier bearing. Short beds came with a 1 piece drive shaft with a slip joint. You just need to find one or get a new one made. Here's what it should look like:
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 01-01-2017, 03:33 PM   #3
ratfreak8871
Thanks Mr chevy, that is what I need. still wondering why I have a 2 pc. it even has the carrier mount riveted in place. Weird......
Old 01-01-2017, 03:39 PM   #4
Mr.Chevy4x4
That is weird. I have never seen a short wheel base truck with a 2 piece from the factory. Any evidence of the truck having been shortened? I have seen long wheel base trucks with factory original 1 piece drive shafts (pretty sure they were all th350 with slip yoke).
Mike
Old 01-01-2017, 04:06 PM   #5
ratfreak8871
no, I cant see anywhere the frame was cut and welded BTW where did you find the pic of that shaft, I will probably go aftermarket for one. don't think I would have any luck at a salvage yard
Old 01-01-2017, 08:02 PM   #6
Mr.Chevy4x4
I just did a quick google search for a picture. Denny's does make good shafts though. I ran one in my rock crawler and never had a problem with it.
http://www.dennysdriveshaft.com/
Mike
Old 01-02-2017, 05:00 AM   #7
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
My swb 78 Big 10 454/400 came from factory with a 2-piece driveshaft.
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
Old 01-02-2017, 07:03 AM   #8
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
My 1985 SWB C10 with a 4.3 and SM465 4 speed also came with a two piece from the factory.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 01-02-2017, 08:28 AM   #9
77 ChevySport
[QUOTE=Mr.Chevy4x4;7811284]That is weird. I have never seen a short wheel base truck with a 2 piece from the factory. Any evidence of the truck having been shortened? I have seen long wheel base trucks with factory original 1 piece drive shafts (pretty sure they were all th350 with slip yoke).
Mike>My 77 Shortbed Chevy Sport with Muncie 465 has the 2 piece driveshaft from the factory. (Picture below) BTW:Center Bearing Support is still available from GM. Larry
77 ChevySport is offline   Reply With Quote
Old 01-02-2017, 10:44 AM   #10
ratfreak8871
Wow thanks guys. never knew gm made them w/ 2pc. Big 10, good to see one behind a 454. guess I'll order some more parts
Old 01-02-2017, 11:21 AM   #11
Keith Seymore
Keith Seymore's Avatar
One piece vs two piece is determined by the shaft critical speed (the rpm at which the shaft starts to bend).
Inputs to critical speed calculations include: wheelbase, shaft overall length (a function of wheelbase and also transmission length), shaft material, tube diameter and wall thickness, rear axle ratio, tire diameter (and speed rating) and anticipated vehicle top speed, as well as any unforeseen destructive system resonances discovered during physical testing.
Changing any of those can make the difference between a particular model getting a one piece or a two piece shaft.
I could envision a small displacement 2wd lwb truck getting a one piece shaft, especially with a lower numerical rear axle ratio, due to a potentially lower top speed and the slower shaft rpm due to the axle ratio. Higher horsepower engines, allowing a higher vehicle top speed, might drive the design into a two piece shaft (or a one piece shaft of more exotic materials). Speed limiting the vehicle, through fuel cutoff or ignition rpm limiting, or releasing a lower speed rated tire, could put you back down in the range when a one piece shaft would be acceptable.
K
http://67-72chevytrucks.com/vboard/s...light=critical
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 01-02-2017, 12:57 PM   #12
Tom
driving is in my blood
Tom's Avatar
MY 78 half ton step side 5.7L with the 8 leaf rear spring pack and sm465 came factory with a 2pc driveshaft. I swapped to a 1pc from a th350 truck when I put the M20 trans in after cutting it to fit.
Old 01-02-2017, 04:34 PM   #13
Mr.Chevy4x4
Wow. Learn something new every day. I've been around these trucks my entire life and never seen a short wheel base with 2 piece shaft. Had several already state on here that their trucks have them. Feel like I've been living under a rock or something! I stand corrected.
To the OP: I would still replace it with a quality 1 piece considering your performance application. Less points of failure.
Mike
Old 01-02-2017, 05:32 PM   #14
USSkoval
You can just unbolt the yoke from the TH400 and use a slip yoke in it's place. It's the usual 32 spline.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 01-02-2017, 07:19 PM   #15
ratfreak8871
I have read somewhere that it shouldn't be done
Old 01-02-2017, 08:25 PM   #16
USSkoval
What was the reason? I did it on my truck a couple years ago and it works fine.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
Old 01-02-2017, 08:30 PM   #17
Jeff's bowtie's
I've removed a fixed yoke and ran a slip yoke for years as well with no issues
Jeff's bowtie's is offline   Reply With Quote
Old 01-02-2017, 11:50 PM   #18
Mr.Chevy4x4
The output shaft for a bolt on yoke 400 has a ridge just past the splines that the slip yoke can bottom out on causing internal damage. If you're going to do this the ridge should be removed.
You can see here where the slip yoke made contact.
Mike
Old 01-03-2017, 01:01 AM   #19
USSkoval
Mike
Makes sense. I remember when I put mine together that the yoke didn't slide in as far as I thought it should have. But it works fine for my application, it really doesn't need much slip travel (stock height shortbed).
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
