01-02-2017, 02:02 AM | #1 |
What's this for?
what is this for? Is this what we used to use on our race cars to keep the engine from pulling the motor mount in two?
http://www.ebay.com/itm/1965-1966-NO...FUxo66&vxp=mtr |
01-02-2017, 02:09 AM | #2 |
Re: What's this for?
the driver's side engine mount had a habit of delaminating under a stressfull load(torque),
this limited the amount of movement ron |
01-02-2017, 11:58 AM | #3 |
motor mount tie down, my 1968 camero had them on it, it was hypo, lots of power
01-02-2017, 12:26 PM | #4 |
Moderator
Nothing to do with hipo. It was a safety recall item for v8s with solid throttle linkage. My 65 Impala 327 has it.
01-02-2017, 01:38 PM | #5 |
So like when the engine would torque up the throttle linkage would bind & cause embarrassing events?
01-02-2017, 01:42 PM | #6 |
But Found Her 25yrs Later!
01-02-2017, 01:44 PM | #7 |
X2^^^ (jayoldschool) The early mounts were NOT interlocking and IF the left mount was bad it could (and did) rip apart under high acceleration and then hold the throttle WIDE open and away you go ..So the recall fix was that kit the dealer would install ...Then they learned how to make them interlocking so not a problem any longer
01-02-2017, 03:38 PM | #8 | |
some guys used chain the ones that were really bad back then were the 58-61 T-birds with 332/352 engs. in them with a/trans. you could pop that left side m/mount at will. we use to repair lots of them ron |
01-02-2017, 04:05 PM | #9 |
I be-live 68 was the first year for throttle cable in GM cars and 73 for trucks ...before cable it was throttle linkage (rods) only
01-03-2017, 12:37 AM | #10 |
It certainly appears (By the drawings anyway) that this kit bolts to the frame in the same proximity as the clutch linkage.
01-03-2017, 12:56 AM | #11 | |
NOS stop lift kits are common for the 64-67 Novas. |
01-03-2017, 01:38 AM | #12 | |
ron |
01-03-2017, 10:30 AM | #13 | |
I could kill him for selling that car and not giving me a chance to buy it....... |
01-03-2017, 02:57 PM | #14 | |
One thing that is odd is all the kits I have seen are 65 and 66 not earlier Hmmmm? |
01-03-2017, 03:16 PM | #15 | |
On the right side the cable just hooked under the engine perch bracket and bolted to two of the exhaust man. bolts |
01-03-2017, 11:44 PM | #16 |
OK then this makes sense, thanks! On my truck it will be using a 400 sb w/ a 4wd transfer, hence a single point rear mount, but a cable throttle for sure. Thanks again!
01-04-2017, 12:11 AM | #17 |
Also on the paper work in the kit it shows how much clearance must be between the throttle rod and the coil on the right side (1/2") and the spark plug wire holder on the left side 1 1/2" MIN...... that must be what they thought was hitting the rod and causing the throttle to stick open as the engine rocked over
