Old 01-03-2017, 10:11 PM   #1
71Ochre
New Carb will only accelerate
New here, just posted in the welcome section.
I have a 71 C10 with a 350 and a Rochester Quadrajet. I have installed a new carb and when I start up the truck it just accelerates and the pressure rises.
Any ideas?
71Ochre is offline   Reply With Quote
Old 01-03-2017, 10:50 PM   #2
Wrenchbender Ret
Re: New Carb will only accelerate
If you mean the engine just races & won't return to idle, It could be the linkage needs adjusting or the secondary throttles are not closed.
Wrenchbender Ret is offline   Reply With Quote
Old 01-03-2017, 10:52 PM   #3
71Ochre
I am new to carbs. I looked over all of the linkages but not sure what would need adjusted.
Old 01-03-2017, 10:57 PM   #4
dmjlambert
dmjlambert's Avatar
I think there should be a return spring pair, there is on my 1969 truck with Quadrajet.
Old 01-03-2017, 10:59 PM   #5
71Ochre
I have a return spring on the drivers side and a divorced choke coil spring on the passenger. I did replace both of those.
Old 01-03-2017, 11:01 PM   #6
geezer#99
geezer#99's Avatar
Take a pic of both sides of your carb.
Otherwise it's just a guessing game.
geezer#99 is online now   Reply With Quote
Old 01-03-2017, 11:17 PM   #7
71Ochre
OK here is each side.
Old 01-03-2017, 11:30 PM   #8
geezer#99
geezer#99's Avatar
Try turning down the high idle.
It's a phillips head screw right under the choke vacuum pot.
Old 01-03-2017, 11:32 PM   #9
71Ochre
OK I think I saw that today. I will try that tomorrow. Thanks.
Old 01-03-2017, 11:35 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Maybe this will help https://www.youtube.com/watch?v=qmFCh8LhRrU
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 01-03-2017, 11:37 PM   #11
geezer#99
geezer#99's Avatar
And your kickdown cable is on the wrong hole. It needs to be where your spring is. And your spring goes where you have the kickdown.
Then your spring will work better.
Old 01-04-2017, 12:26 PM   #12
LockDoc
The Older Generation
LockDoc's Avatar
Yup, no tension on the return spring....
LockDoc
Leon
Old 01-04-2017, 01:01 PM   #13
67ChevyRedneck
67ChevyRedneck's Avatar
Are you letting it warm up and it's still doing it? That's how carbed vehicles warm up, they have a choke/fast idle, it can take a few minutes when it's cold for the idle to drop to normal.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-04-2017, 05:00 PM   #14
Wrenchbender Ret
What part of town are you in? If you can't get it worked out, I might be able to stop by & take a look at it.
George
Old 01-04-2017, 05:09 PM   #15
demian5
demian5's Avatar
Whats up with the vacuum hose going between manifold and ported vacuum over the fuel inlet?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-04-2017, 05:52 PM   #16
trucks72
trucks72
trucks72's Avatar
I think his kick down cable is in the right spot. His spring is just to long to give any tension. Just needs a shorter spring.
trucks72 is offline   Reply With Quote
Old 01-04-2017, 11:46 PM   #17
jkeady
jkeady's Avatar
Yeah, I agree- I can't quite tell from the photos but if you ARE connecting your ported and manifold vacuum ports on the front of the carb... that's going to be a problem.
Josh
'70 Custom Camper / 20
jkeady is offline   Reply With Quote
