Old 01-04-2017, 04:31 PM   #1
Dmax21
203 transfer case problems
I have a 4x4 with a 203 transfer case with lock out hubs and I think it may have been converted but don't know for sure, anyways I was using 4x4 and while driving slowly the front wheels locked up and would not free up and I couldn't get the transfer case back to 2wd so I kept trying to backup and go forward and it freed up and made a pop sound and now the 4x4 will not work, I can lock it into 4lo and it will reduce the gears but no power to the front wheels. Now I haven't tore into anything yet but what do you guys think the problems could be or could have caused this? any tips would be great.
Dmax21 is offline   Reply With Quote
Old 01-04-2017, 04:38 PM   #2
b454rat
Re: 203 transfer case problems
Prolly chain......
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 01-04-2017, 05:12 PM   #3
Dmax21
is there a way to check before I remove it?
Old 01-04-2017, 06:55 PM   #4
b454rat
Not sure if there is an inspection cover to see chain or not. Pull the PTO cover, maybe that will give you enough to take a look see.
Old 01-04-2017, 07:31 PM   #5
cadillac_al
How do you know when it's in 2WD? The 203 is supposed to be full time 4WD.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 01-04-2017, 07:37 PM   #6
Dmax21
I believe the 203 was converted since it had lock out hubs and when I shift too 1 click below N on the transfer that would be 2wd on my truck.
Old 01-04-2017, 08:55 PM   #7
kwmech
You won't see much if you pull the pto cover x'cept a fat bull gear. On the rear of the case there is an aluminum cover, 8 bolts holding it on. After you drain the oil remove the 8...... 9/16'' headed bolts. Slip in a putty knife and work around the plate. Get ready to catch a quite a few needle bearings that may fall out of the pocket that supports the rear of the front drive gear. From there you can see part of the chain and possibly determine the damage if any.
Old 01-04-2017, 09:13 PM   #8
franken
Were you driving on pavement when things got weird? You don't drive on pavement with the hubs locked in 4x.
Old 01-04-2017, 09:30 PM   #9
b454rat
If it's a 203 kinda dont' have a choice, part time kit or not.
Old 01-04-2017, 10:39 PM   #10
Dmax21
No I wasn't on pavement, but if I was I don't see what pavement would have to do with it.
Old 01-05-2017, 12:05 AM   #11
Dmax21
One more thing, if the chain is broke would it still reduce the gears when in 4lo?
Old 01-05-2017, 02:48 AM   #12
andrewmp6
You might have better luck in the 4x4 part of the forum http://67-72chevytrucks.com/vboard/f...splay.php?f=30
Old 01-05-2017, 03:40 AM   #13
hatzie
Moderator
hatzie's Avatar
If you run a converted NP203 in 4wd or a stock case in LOC on pavement the transfer case will bind up. Drive it in reverse with the hubs locked in til you can shift her. It may make nasty noises when she finally condescends to shift but I doubt you really hurt it. You have to work at it to kill a 203.
If the chain broke the case would bind up and stop no matter what position you set the shifter in because it doesn't ever stop turning. She would make a heckuva racket driving too.
You can twin stick a stock NP203 and they work a LOT BETTER. I did one years ago on a 1979 Dodge 3/4ton Power Wagon.
Stick 1 is HI-N-LO.
Stick 2 is LOC and AWD (not locked). AWD on pavement and LOC when you need traditional 4wd.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-05-2017, 03:49 AM   #14
Dmax21
Stick 1 is HI-N-LO.
http://www.youtube.com/watch?v=rpekJRFlxz4
It made a pretty loud pop when the front tires finally unstuck and I tried backing up but the front wheels wouldn't roll at all until the pop noise, now no power is getting to the front wheels, i can drive it no problem without any noise at all just no front wheel action when I shift too loc.
Old 01-05-2017, 04:07 AM   #15
hatzie
Moderator
hatzie's Avatar
Some of the part time kits had a pretty bad rep for weak internal parts. However it should be making nasty noises even in 2wd. You can get to most of the diff parts by pulling the tail housing.
If it really isn't working you'll have to pull the case out to fix it or replace it.
If the 203 isn't making nasty noises in 2wd I'd be tempted to rule out the front axle. Set the front axle on Jackstands and see if you can turn the front propshaft with the transfer case in 2wd or neutral. Maybe even pull the front propshaft off the diff and or transfer case flanges and see if the front wheels will turn with the hubs locked in.
If they don't turn pull the diff cover off the front axle and take a gander.
Old 01-05-2017, 04:29 AM   #16
rich weyand
rich weyand's Avatar
How do you know that no power is getting to the front wheels?
One thing you can do that is easy is put the front hubs in free, and have someone drive a few feet in HI while you look from the side. A part-time 203 won't spin the front shaft. Now do the same thing in HI LOC. The front shaft should spin if the 203 is working.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 01-05-2017, 08:26 AM   #17
Dmax21
I will try these test out in a couple of days since its really cold here now, also I know the front end isn't getting power because I was in 4 loc going through some mud and almost got stuck and was spinning trying to get out and only the rear wheels where spinning.
Old 01-05-2017, 09:07 AM   #18
mongocanfly
mongocanfly's Avatar
Very possible the front diff is broke..easy to check..just pull the cover and look...and if its got manual hubs one of them could be broke...I had one disintegrate on my ol 72 one time..well ..I see hatzie was already pointing towards that
Old 01-05-2017, 10:40 AM   #19
Dmax21
When I lock the hubs I can't spin the axle going to the wheels and I can with them unlocked, so I assumed they were working, also I had thought of the front diff but I figured it would be making noises while I'm driving. I'm going to check that out with a few of the other things and if I can't find anything, I guess I will have to take it too a shop. Thanks for the help it's really appreciated.
Old 01-05-2017, 10:53 AM   #20
hatzie
Moderator
hatzie's Avatar
This sounds more like the front axle. Unlocking the hubs literally disconnects the axle half shafts from the hubs so if there's a problem that's locking up the diff it will not rear its' ugly head with the hubs unlocked.
Can you spin the wheels or the front prop shaft with the hubs locked and the transfer case in Neutral?
Old 01-05-2017, 11:46 AM   #21
Dmax21
Can you spin the wheels or the front prop shaft with the hubs locked and the transfer case in Neutral?[/QUOTE]
I will try this and report back, all this happened a few weeks ago and i'm just now getting around to messing with it but seems like I tried spinning the front shaft and it would with hubs unlocked but with the hubs locked I couldn't spin it but its been a few weeks so I will re try this, also I can drive the truck with the hubs locked now and it won't make any noises at all, it just won't go into 4x4.
Old 01-05-2017, 12:50 PM   #22
kwmech
It's not going to spin with the hubs locked unless you end up rolling the truck at the same time
Old 01-05-2017, 12:59 PM   #23
hatzie
Moderator
hatzie's Avatar
It needs to be up on jack stands to get the wheels off the ground. I didn't state that.
Old 01-05-2017, 03:20 PM   #24
Dmax21
I will do it this weekend and report back.
Old 01-09-2017, 07:45 PM   #25
Dmax21
Ok here's what I have so far... hubs locked with transfer in neutral I can spin front shaft no problem and this is with front wheels off the ground and transmission in neutral or drive either one. I also tried to spin the shaft with transfer in 4hi and cannot spin it and I can spin the front tires and the front shaft doesn't move. What do you guys think?
