Old 01-04-2017, 09:06 PM   #1
AcampoDave
AcampoDave's Avatar
TKO 600 and Low Hump
I wonder does the tko600 fit a low hump floor? I did a lot of searching, but just didn't get a good answer. I have a '66 and the floor is low and one solid piece. The cab was originally from an automatic truck. As of now tho' I have an aging Saginaw 4 speed. It's mated to a stock cast iron bell that came with the '63 manual tranny frame I used when I assembled the truck. I'm just kinda weighing my options here as I would like to stay with a stick.
AcampoDave is offline   Reply With Quote
Old 01-04-2017, 09:33 PM   #2
oliver63
oliver63's Avatar
Re: TKO 600 and Low Hump
I have a TKO 500 in my 63...it didnt fit with the low hump.
1990 Silverado Sport
2010 Silverado K1500
1996 K2500
oliver63 is offline   Reply With Quote
Old 01-05-2017, 11:14 AM   #3
AcampoDave
AcampoDave's Avatar
Thanks, if a 500 doesn't fit a low hump, odds are that the 600 won't either.
Old 01-05-2017, 11:21 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Externally the 500 and 600 are the same size. It's internal ratios and a couple parts that changes the torque rating (500 ft. lbs or 600 ft. lbs input torque).
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-05-2017, 07:54 PM   #5
PORKY
PORKY's Avatar
Take a look here
http://67-72chevytrucks.com/vboard/s...d.php?t=704714
Good luck!
PORKY is offline   Reply With Quote
Old 01-05-2017, 08:45 PM   #6
AcampoDave
AcampoDave's Avatar
Originally Posted by PORKY View Post
Nice! So your carpet still fit after the nip and tuck to the tunnel? That would be concern of mine too having a non removable hump and all.
Old 01-05-2017, 09:27 PM   #7
PORKY
PORKY's Avatar
I haven't got there yet. The days just fly by.
I think I'm going to fabricate a small spacer and cover it with matching red leather like the seat. It'll only be about 1-1/2" high. Then I will screw the boot to that. The carpet will be under the spacer. I may make it into a cup holder/console. If you have any good ideas, please pass them along.
