Old 01-07-2017, 12:48 AM   #1
rally
Custom digital gauges?
So I can do programming enough to build my own digital gauges using a raspberry pi and an analog to digital converter, but what I don't have is an electrical background. I know there's enough tutorials to use a microcomputer to read OBD info, but what I can't find is a pre-OBD tutorial to read our gauges and build a monitor for engine temperature, RPMs, etc, for our trucks using a microcomputer using an ADS1115 for converting our sending units to digital format.
More specifically, reading the tach signal from the distributor (my distributor has a tach output connection, not sure if all do), reading engine coolant temp, etc. If someone could answer my questions about how to step down voltage signals or amplify signals (which the ADS1115 should amplify signals I believe) to prevent frying the computer or allow the computer to read minor changes in the signals correctly, that would be awesome.
I understand the purist POV that I can just install a tach and use the existing gauges, but I'd like to try to build a digital setup others could use if they wanted. Plus I think it would just be cool.
Anyone with an electrical background able to understand how the sending units work and have a rough idea how to convert them to human readable format? Things like voltage ranges, resistance ranges, etc.
I'm currently running an early 80s sbc 350.
Is this something people are even interested in? I figured it might be a fun project. Might take a while though.
1969 Custom C10
rally is offline   Reply With Quote
Old 01-07-2017, 07:52 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Custom digital gauges?
They sell custom gauge packages that you build your self. I really can't see doing this. The custom gauges can be made for any application. Just to easy and all the electrical stuff is already figured out for you.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-07-2017, 09:54 PM   #3
Robznob11
Robznob11's Avatar
Save the hassel. Ebay intellitronix cheap and lifetime warranty! And build your own option if you choose that route.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 01-07-2017, 09:57 PM   #4
Willie Makeit
Willie Makeit's Avatar
seen it done with later model LS swaps using the data from the OBD2 port. not sure how you would import that type of data straight into the raspberry from the OEM style sending units.
Willie Makeit is offline   Reply With Quote
