01-08-2017, 10:30 PM | #1 |
73-87 gas tank question
Hi, Wondering if someone can help out here.
I shortened a V3500 crew cab(1989) 4x4, to a short box. I am wondering about buying two new tanks. First question is...can I get a sending unit with a larger line coming out for my diesel engine? I need a 3/8" two line. Second question...anyone ever tie these two tanks together so you don't have to fill from both sides and you don't need a switch to go from one tank to the other? I would rather fill from one side, and draw fuel from one side. I was thinking of brazing a nipple on bottom of both tanks and connect them. Thanks I'm close to finishing my project. I will have to post some pictures of the progress I have made. I used a 12 valve cummins, NV4500, NP205, Dana 80. next is working on exhaust. Trying to fit 4"(its a bit tight). And I need to figure out fuel tanks. |
01-09-2017, 08:57 PM | #2 |
Re: 73-87 gas tank question
I've seen on here were guys have replaced the siphon tube with a larger one. I bet if you search you can find it.
Personally I don't think the risk of a transfer tube in the tanks is worth the gain.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
01-09-2017, 11:12 PM | #3 |
A bottom transfer tube runs the risk of getting ripped off if it gets snagged on brush or road debris. Plus, if you parked on a steep side slope, enough fuel could run to the low tank to over fill that tank and leak out the vents.
01-12-2017, 12:15 AM | #4 |
For a while, there was a kit that replaced anf connected filler tubes above the tanks. You have to slow down a bit on filling though. Otherwise it is nice to fill both from either side.
jjmorrse 86 C30 crewcab big dooley. 454- 400 |
