Old 01-10-2017, 08:03 AM   #26
Bigdav160
Bigdav160's Avatar
Re: Rear end questions
Originally Posted by El Dorado Jim View Post
you dont grease the rear bearings on a full floater like you have, the gear oil in the rear end travels to the ends and keeps things lubed...when you initially install new bearings, you can put some white grease on them so they dont run dry until the oil gets to them and the white grease will mix with the gear oil....
Sorry Jim, read the service manual, it says to pack the bearings with grease.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-10-2017, 08:10 AM   #27
Andy4639
Old member
Andy4639's Avatar
Question Re: Rear end questions
Bigdav160 which manual are you reading? I have all the manuals for the C-10.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
