Old 01-11-2017, 12:18 AM   #301
markeb01
Senior Enthusiast
markeb01's Avatar
Re: New member with a 1960
The reflections from all that work is simply amazing! Nice job!!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 01-11-2017, 09:44 AM   #302
The1960APE
The1960APE's Avatar
Thank you sir!
1965 Olds 442 "Project Oldmobile"
1971 2wd GMC Jimmy..."The Orangutan"
1961 Apache "The Ape"
http://67-72chevytrucks.com/vboard/s...d.php?t=679735
The1960APE is offline   Reply With Quote
Old 01-26-2017, 10:24 PM   #303
wolfsden
wolfsden's Avatar
Originally Posted by par4tom View Post
You can get 10" wheels in the back depending upon the offset. Zero offset may create a rubbing on the fender wells and you may have to use a 1/2 inch spacer.
Also, watch over the top of the tires in the rear. There is an outer fender edge and bracing that could come into play depending upon the size wheel and tire and how low you set the truck.
I just went through this with 20 inche / 10" wide wheels, tried 285's, then 265's then 255 20's before I finally got them to fit. I think there is about 12.5" of room between the fender lip and the bed so tire width is not unlimited.
On the front, you shouldn't have a problem depending upon how low you choose to go. I used 2.5" drops in the front and then cranked the torsion bars up as the 8.5" 245's were rubbing the fender lips. I am rolling the lips up this week to get a little bit more clearance. BTW, mine only rubbed on the passenger side and on turns to the right while hitting a slight bump.
Great looking truck you got there...I like it a lot!!! Here are the 10 inch wheels in the rear...Foose Legends. My rear axel is on bags so I run it just a bit lower then this right now...no rubbing!
Your running 20X10 rims front and back with 255 tires and no rubbing just a bit on passenger front? What is the tire exact size?
wolfsden is offline   Reply With Quote
Old 02-04-2017, 01:35 AM   #304
gringoloco
A guy with a truck
gringoloco's Avatar
Really digging it. What size are the rear tires?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-07-2017, 12:40 PM   #305
The1960APE
The1960APE's Avatar
The rears are 305/35/20 We have realized that I have plenty of room in the rear after the tubs and narrowing the rear end, the next set will more than likely be a 345 or a M/T tire a bit wider!
Old 02-07-2017, 12:43 PM   #306
The1960APE
The1960APE's Avatar
Its been a while since posting, we pulled off the Apache for a few weeks to work some bugs out of my 1965 Olds 442......come buy it please..LOL Its full steam ahead for the Ape now! IT has an appointment with Mr. Interior man mid March! HURRY HURRY
Old 02-10-2017, 03:24 PM   #307
The1960APE
The1960APE's Avatar
A little more progress and some goodies from the chrome shop.....
Old 02-10-2017, 04:12 PM   #308
62stepside longbox
62stepside longbox's Avatar
That chrome looks great! Roughly How much did it run you if you don't mind me asking?
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 02-10-2017, 11:25 PM   #309
DPowers
One foot in front of the other
DPowers's Avatar
Chrome looks great.
DPowers is offline   Reply With Quote
Old 02-11-2017, 11:29 AM   #310
graymage
graymage's Avatar
looks real nice, I am getting lots of ideas for my 66
graymage is offline   Reply With Quote
Old 02-11-2017, 09:25 PM   #311
metalprelude
I'm finally getting started on my 61 Apache. Where did you get your booster and master cylinder setup?
metalprelude is offline   Reply With Quote
Old 02-14-2017, 10:45 AM   #312
The1960APE
The1960APE's Avatar
it was 125.00-150.00 per piece, Thanks
Old 02-14-2017, 10:46 AM   #313
The1960APE
The1960APE's Avatar
Pirate Jack on Ebay, they are local, I am running the bracket that CaptainFab here on the forum makes, it was an AWESOME fit!
Old 02-14-2017, 10:47 AM   #314
The1960APE
The1960APE's Avatar
LOL hopefully not from our crazy shenanigans......
Old 02-14-2017, 10:47 AM   #315
The1960APE
The1960APE's Avatar
Originally Posted by DPowers View Post
Chrome looks great.
Thanks Dr. Powers!
Old 02-17-2017, 10:13 AM   #316
The1960APE
The1960APE's Avatar
The engine is back in, AC vents finalized, double sound deadening finished, Pedals installed, column painted and installed... She should start moving along now!
Old 02-17-2017, 11:15 AM   #317
graymage
graymage's Avatar
Thumbs up Re: New member with a 1960
I like all the shenanigans, my truck had a manual. is that auto brake pedal factory?
Old 02-17-2017, 11:29 AM   #318
The1960APE
The1960APE's Avatar
We did use the factory arm, we bent it slotted it, welded a new pad on it to fit the new pedal cover, powder coated it and there you have it, once its hooked up it sits much closer to the floor like a modern truck!
Old 02-17-2017, 11:32 AM   #319
graymage
graymage's Avatar
perfect I like it
Old 02-17-2017, 11:54 AM   #320
The1960APE
The1960APE's Avatar
perfect I like it
Thank you sir, I am really excited to get it over to the upholstery shop.....It is turning out to be a very unique build, I don't know if I have seen anything quite like it. I think interior can really make or break a project.....We have a few tricks up our sleeve....Hopefully it turns out nice!
Old 02-17-2017, 02:21 PM   #321
graymage
graymage's Avatar
we will be watching and taking notes, stealing ideas, lol!!!
Old 02-17-2017, 04:20 PM   #322
forestb
forestb's Avatar
I think you need to change the name of this thread. I would no longer consider you a new member.
forestb is offline   Reply With Quote
Old 02-17-2017, 10:35 PM   #323
62stepside longbox
Old 02-20-2017, 11:17 AM   #324
The1960APE
The1960APE's Avatar
Old member with a 1961? LOL
Old 02-20-2017, 11:37 AM   #325
62stepside longbox
Originally Posted by the1960ape View Post
old member with a 1961? Lol
