Propostioning valve wire
Well I ended up repairing my old Propostioning valve wire. After taking a look at at work. I found that some of the wires by the connector were broken off. I took it apart and soldered a new Brown wire to the connector since I could not put on a new connector since I don't where to purchase of one. I think it came out pretty good. Thanks to all who tried to help me.
Ramiro |
The Older Generation
Re: Propostioning valve wire
That should work, and it looks good. There isn't much pressure on it. I think I would put a wire tie on it to one of the brake lines just to keep it from moving around.... LockDoc
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
You can ground that wire with the key on and the brake warning light in the dash should illuminate. It normally comes on when starting the engine also.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
