Old 01-12-2017, 10:38 AM   #26
chrismoore701
chrismoore701's Avatar
Re: Removing the bow in the hood
Placed two (2) 3" 2x2's under the hood in the channel at the side, one (1) near the front and the other just in front of the hinge. Took a 4x4 and placed it under the 2x2's and clamped in place with some rubber clamps. Placed a 6" 2x4 on the hood on a towel. Measured the distance I need to squeeze the hood and put a 3/4" pipe clamp on there and squeezed slowly. Over squeezed a little and waited. Removed and checked. Repeat as needed. No damage.
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 01-12-2017, 06:30 PM   #27
LT7A
Good work on this. You have a nice looking truck and it would have been a shame to damage that hood. Do you need new hinges? Can you use the ones you have? If they're rusty can you soak them in phosphoric acid to get rid of the rust and then keep them lubed from there on out? Sandblasting may put grit into the pivot points, but it seems like phosphoric acid would just soak through and clean out any rust. My truck is a later model so I don't really have this issue, but I like the white spray lithium grease on door hinges and hood hinges. Seems to work well.
Old 01-12-2017, 08:02 PM   #28
UKNOWME
UKNOWME's Avatar
do not buy aftermarket stock replacement hinges. They are junk. Find someone online or ebay that sells rebuilt OEM hinges or spend the $$$$ and buy some billet hinges.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-12-2017, 08:05 PM   #29
UKNOWME
UKNOWME's Avatar
Here is the guy I bought a set of OEM rebuilds from in the past. You might message him and ask if he has any available.
http://www.ebay.ca/usr/edoutdoorsman1980
I've also bought these but didn't like they way they fit
http://www.eddiemotorsports.com/prod...ck-ms149-24-2/
And lastly I have these but yet to install...
http://67-72chevytrucks.com/vboard/s...d.php?t=719575
1964 Chevy c10
Old 01-12-2017, 10:02 PM   #30
chrismoore701
The hinges I have are just loose. Any other thoughts on the after market hinges?
Chris
Old 01-12-2017, 10:34 PM   #31
Houston Ben
Houston Ben's Avatar
How good is USA1industries? Are their products good, I fill my cart up but don't want to buy junk.
Thanks for any help!
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
Old 01-13-2017, 12:33 AM   #32
TKCR
TKCR's Avatar
Everything I've ever gotten from them has been good stuff.
Old 02-12-2017, 10:03 AM   #33
ChevyC102007
ChevyC102007's Avatar
I got both the hinges a springs from www.rockauto.com (both hinges/springs had AC Delco part numbers and stock numbers on them) of course I bought the spring tool from LMC.
Sadly I have a kink in my stock hood (was there before I put in the new hinges) and am wondering if I can just repair that with a set of the hood stiffiners or if Id just be better off getting a new hood and have done with it.
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
2001 Dodge Ram Sport 1500 4x4. (old ride)
1987 GMC V1500 Sierra Classic ("new" ride)
ChevyC102007 is offline   Reply With Quote
Old 02-13-2017, 11:15 AM   #34
barry1982
Hi Guys.... Just throwing in my 2 cents...... I have had at least 15 squares in the last 30 years. In my opinion..... there is nothing wrong with the stock hood hinges on these old girls. You just have to give them a little shot of oil once in a while. Personally, I give them a few drops in all the pivots every time I change engine oil. Never had a hood "bow".
barry1982 is offline   Reply With Quote
Old 02-15-2017, 06:22 AM   #35
cadillac_al
Me too Barry. Last week I was having trouble closing my hood on the K20. I slammed it down and it didn't latch. Hmmm, I opened it and slammed it again. Didn't latch. I was thinking, "should I grab onto this thing with both hands and reef her down or go to the shop and get some oil?" I got the oil and lubed her up and it dropped closed with one hand like it's supposed to. I guess if you are out in the woods with no oil you would have to slam it down the best way you can and probably bend it. As long as you have access to oil, it should close with one hand.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 02-15-2017, 06:45 PM   #36
chrismoore701
What is the best way to oil these hinges? WD40 is messy. a little 3 in 1?
Chris
