01-13-2017, 03:46 PM | #1 |
Need advice on removing steering wheel hub
This is my first crack on removing my steering wheel and I'm stuck at the hub. Do I need a steering wheel puller to remove the hub? Thanks in advance on any help!
- Jeremy |
01-13-2017, 04:16 PM | #2 |
Re: Need advice on removing steering wheel hub
Of course you need a steering wheel puller, you always need a steering wheel puller...use the puller in the straight across 5/16 bolt holes and pull it. You didn't have to remove the wheel from the hub to do this. You can use a harmonic balance puller if you get some 5/16 course thread bolts and flat washers the right length.
Nice wheel by the way... |
01-13-2017, 04:21 PM | #3 |
I would always recommend using a steering wheel puller. I know other have their special ways of removing them, but I don't recommend any of them.
01-13-2017, 04:34 PM | #4 |
yes you need a steering wheel puller, you should be able to get one at autozone , buy it dont rent it ,then you have it forever
01-13-2017, 08:01 PM | #5 |
or the two person way..
put the nut back on but not tight, just flush with the shaft end.. and while one person is pulling on the wheel , the other gives the shaft/nut a good smack with a hammer.. pop it's loose, take nut off and remove.. same idea that works on tie rods and ball joints.. |
01-13-2017, 09:14 PM | #6 |
Thank you for the quick responses! The puller got it done.
01-13-2017, 10:37 PM | #7 |
You know I figured the same thing, bought one, got this far, hooked it up, and it came off so easy I'm positive I could've just pulled on it.
1969 C10 SWB Stepside, 350, TH350, FiTech Go Street Fuel Injection |
01-13-2017, 11:15 PM | #8 |
01-14-2017, 12:30 PM | #9 |
steering wheel pullers are way overrated I've removed thousands of steering wheels and hubs by myself without ever needing one// you just need to b able to outthink it
01-14-2017, 01:35 PM | #10 |
I've tried to outthink my column but it always ends up in a stalemate, just like our staring contents. I use a harmonic balancer puller with skinny bolts, but whatever works!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
01-14-2017, 09:09 PM | #11 |
I don't like to stress out steering wheels by jerking on them too hard. It can cause cracks in the finish of the wheel. The puller saves those worries.
01-15-2017, 08:40 AM | #12 |
Old member
Puller's are cheap. They don't put stress on the wheel as mentioned.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
