Old 01-14-2017, 05:12 PM   #326
donandal
Re: Plus Five
the install of the gauges was a pain...
they come in from the back and there isn't much room.
speaker covered in fabric, epoxied on the back side.
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 01-14-2017, 05:23 PM   #327
donandal
Re: Plus Five
I made up short gauge harnesses to make the installation easier,
but the gauge brackets and bezels were a pain in the....
Glad that is behind me.
Now there are just a few wires left, brake switch, turn and high beam
indicators, hood tilt switch and the wiring will be finished.
I'll have to check all the lights , then it's on to filling
the fluids, and bleeding the brakes.
53 Chevy Pickup
Old 01-14-2017, 05:31 PM   #328
donandal
Re: Plus Five
if you are wondering,
I'm not too crazy about the steering wheel either.
but that can wait.
53 Chevy Pickup
Old 01-15-2017, 10:01 AM   #329
solidaxel
solidaxel's Avatar
Re: Plus Five
I was about to ask about the steering wheel.............. thanks !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-15-2017, 03:12 PM   #330
donandal
Re: Plus Five
finished the dash...
53 Chevy Pickup
Old 01-15-2017, 03:21 PM   #331
donandal
Re: Plus Five
I used the original glove box latch, but had to rebuild it.
The pivot piece has little round pins molded into it that
were nearly worn off. I took it apart cleaned it up,
and drilled it out for a new pivot pin. I made the pin from
coat hanger wire.
I sprayed some white lithium grease into it, readjusted the striker
tab and it closes like new.
53 Chevy Pickup
Old 01-15-2017, 04:57 PM   #332
RockinKees
RockinKees's Avatar
Re: Plus Five
Very nice!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 01-16-2017, 03:15 PM   #333
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Plus Five
Interior is looking amazing!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 01-17-2017, 10:37 AM   #334
slydogg76
Re: Plus Five
Yes, very nice!
slydogg76 is offline   Reply With Quote
Old 01-17-2017, 10:52 AM   #335
II_Slow
II_Slow's Avatar
Re: Plus Five
What's the plan for the steering wheel? Lot's of nice choices out there.
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and
47RH AOD transmission
http://67-72chevytrucks.com/vboard/s...d.php?t=640042
II_Slow is offline   Reply With Quote
Old 01-17-2017, 06:02 PM   #336
donandal
Re: Plus Five
I'm not really sure yet.
I've read every steering wheel thread I can find.
I'm hoping one just jumps out at me....
53 Chevy Pickup
Old 01-18-2017, 02:41 AM   #337
Nut Case
Nut Case's Avatar
Re: Plus Five
Donandal
Just a thought, considered the new lower valance that you created, maybe paint it the same as the exterior color.
Truck is fandamtastic
NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 01-18-2017, 07:19 PM   #338
donandal
Re: Plus Five
well,
big milestone today.
no wires hanging down anymore!
I finished all the wiring.
Checked, horn,lights,turn signals,backup lights,etc. and everything
worked with no problems so far!
53 Chevy Pickup
Old 01-18-2017, 07:32 PM   #339
Big Daddy Bear
Big Daddy Bear's Avatar
Re: Plus Five
Looks great!
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
Old 01-18-2017, 07:35 PM   #340
Flysocal
Re: Plus Five
Man. This truck is looking incredible! Do you work at a hotrod shop or something? Professional job to say the least! I can see it fetching six figures on the block regardless of wether you want to sell or not, it's nice to know it holds value. Can't wait to see more progress.
Flysocal is offline   Reply With Quote
Old 01-18-2017, 07:47 PM   #341
donandal
Re: Plus Five
I'm an airline pilot, but I did work at a tool and die shop in high school
and college. I really enjoy doing this stuff.
My wife cracked up when I showed her your six figures comment...
she joked that she's going to haul mulch with it just so it gets driven!
I mostly like the building part, not the driving or shows.
53 Chevy Pickup
Old 01-18-2017, 07:53 PM   #342
donandal
Re: Plus Five
Originally Posted by Nut Case View Post
Donandal
NC
I've seen some really nice painted steering wheels, but I'm
a fan of the padded thicker style wheels.
53 Chevy Pickup
Old 01-18-2017, 08:35 PM   #343
lynx5653
lynx5653's Avatar
Re: Plus Five
truck is quite a piece of work, enjoy
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline   Reply With Quote
Old 01-20-2017, 04:36 PM   #344
donandal
Re: Plus Five
Installed the seats and center console,
53 Chevy Pickup
Old 01-20-2017, 04:39 PM   #345
donandal
Re: Plus Five
I need to finish the wiring for the seats and a center console
power supply.
I also bought the remaining fluids, so getting closer to
first start!
53 Chevy Pickup
Old 01-21-2017, 07:04 PM   #346
donandal
Re: Plus Five
Originally Posted by solidaxel View Post
First three..... check your dip stick before starting the engine and see how full the pan is then one after the other
Hey
Thanks for the info,
I put three in and filled the pan, so I'll add the rest when
I start it up.
Maybe some time this month.
I cranked the engine about 10 seconds, then waited a minute
and cranked another 10 seconds and had good oil pressure.
fuel and ignition were disconnected
Sweet!!!!
53 Chevy Pickup
Old 01-22-2017, 11:33 PM   #347
solidaxel
solidaxel's Avatar
Re: Plus Five
There are some tricks to filling the rad./block !
Are you using distilled water?
LS 3 4L70E
Old 01-23-2017, 06:59 AM   #348
donandal
Re: Plus Five
I bought distilled water and pre mixed my own.
I haven't filled it completely yet. I have about 3 gallons in so far,
but I haven't started it yet, just cranked it a couple times to check
for oil pressure.
I'll have to read up on bleeding all the air out. I'm heading out on
a two day trip this morning, so I'll get up to speed on that on my
layover.
I'm going to get a crew together to be observers and helpers to bleed
all the systems and spot leaks when I fire it up.
Maybe this weekend!
53 Chevy Pickup
Old 02-05-2017, 04:16 PM   #349
donandal
Re: Plus Five
I have most of the fluids in the truck, but I decided I don't
want to put the gasoline in the tank until I get some warmer
weather. I'd just as soon not start the garage on fire if I have
a leak, so I'll start it up outside.
In the meantime, I started on the cover for the sub woofer
and radio amplifier and radio.
I'm building this from .060 3003 aluminum sheet. When it's finished
I'll paint it to match the satin dash color.
The sub woofer I bought fits nicely behind the seat. It leans back at
about the same angle as the seat back, so it doesn't come close to
hitting the seat, even when fully extended back.
53 Chevy Pickup
Old 02-05-2017, 04:22 PM   #350
donandal
Re: Plus Five
the factory sub woofer box is fastened to the aluminum front with
the speaker grill ring so it shouldn't leak air.
the side panels will lean back to match the front cover and
will be trimmed to follow the cab corners.
The two ovals drawn out in marker will be cut out and perforated
aluminum screen will be attached to ventilate the amp.
53 Chevy Pickup
