Old 01-15-2017, 09:52 PM   #1
ghostflyer
1-Ton Master Cylinder Reservoir Losing Fluid
1986 C-3500 single cab dually w/hydroboost. Front discs, rear drums.
The pedal was a little soft today, so I opened the master cylinder. The fluid started to run out over the top of the back reservoir. (I assume that's for the front discs.) The front reservoir was nearly empty. It appears that fluid is being transferred from the rear brake reservoir to the front. Is that possible, or is the rear brake system simply leaking?
Thanks for your help, Les
ghostflyer is offline   Reply With Quote
Old 01-17-2017, 12:11 PM   #2
ghostflyer
Re: 1-Ton Master Cylinder Reservoir Losing Fluid
Anyone???
Old 01-17-2017, 01:12 PM   #3
erichevy
erichevy's Avatar
My 79 GMC 1 Ton loses fluid too. Also has the Hydroboost system. Mine appears to push fluid past the lid and seal for some reason... i replaced the gasket under the lid and it still leaks. Maybe mine is building up too much pressure. Really not sure.
1979 GMC C35 - Farm Work Truck
1986 GMC C25 Crew Cab
1987 SWB R10
erichevy is offline   Reply With Quote
Old 01-18-2017, 08:37 AM   #4
walkerb
walkerb's Avatar
Mine does the exact same except Im losing it out of the large reservoir in the MC. I think it leaking from the bottom of the hydro boost. Between where the MC and the hydro meet.
Like there's too much pressure
Never been able to figure it out other than just replacing the hydro.
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
