Old 01-16-2017, 12:14 AM   #1
mehoff400
power drum brakes
looking to add power drum brakes to my truck. i have done some research but seems like a lot of conflicting information. really looking for the easiest solution
i am assuming its bracket from captainfab but what is the process of getting the correct brake booster?
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 01-16-2017, 01:33 AM   #2
Captainfab
60-66 Nut
Re: power drum brakes
You will want a booster and master for a '67-'70 truck. Those boosters are on the compatible booster list in post #183 of the for sale thread and also on the list that comes with every booster bracket.
Old 01-16-2017, 08:55 AM   #3
mehoff400
will i need to change the pushrod so it will be the correct length if i use a 67 c10 booster?
My truck
Old 01-16-2017, 10:46 AM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Buy the booster and master as a matched set.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-17-2017, 12:55 AM   #5
Captainfab
60-66 Nut
You will have to cut the end off of the booster pushrod and trim your original pushrod to length and either weld them together or thread both and use a coupling nut. You could also use a sleeve and pin method to join them.
