![]() Join Date: Feb 2015
flywheel removal for a 57 235
i am totally stuck. there are 2 bolts at the top/ inside of the bellhousing that i can't get to without removing the flywheel. trouble is- i have zero idea how to remove the flywheel. there are supposedly some sort of pins holding it in place? i don't see any- just some holes. i tried tapping on it- no result.
any photos available of what i need to do? thanks a lot, Scott |
Moderator
![]() Join Date: Dec 2012
Re: flywheel removal for a 57 235
I did this recently on a 235 that we put in a 63. You have to take the flywheel bolts out, remove the flywheel, then you'll get the other bellhousing bolts.
Where are the flywheel bolts
I removed the 6 around the shaft but cant pull it off |
![]() Join Date: Oct 2007
The flywheel is just a very tight fit to the crankshaft. Rap it a few times with a hammer and it will start coming off.
I figured it out
Thanks so much Scott |
