Dash Cluster
I'm almost done wiring up my son's truck with a new wiring harness from American Autowire. Today I changed his temperature gauge on his dash cluster. When i took it out the cluster to replace the wiring. I cut some wires that were attached to the cluster. Would I have to reconnect this wires back up to the new wire harness? His original wire harness was like a rat's nest. i think that's why they added the wires on back of the cluster to make some of the gauges work. Can somebody tell me if the back of my cluster looks okay and if I can remove those wires that are attached.
thanks, Ramiro |
Re: Dash Cluster
It looks like your printed circuit has been hacked up. If you remove the external wires, you might need a new circuit board to connect the gauges through the standard wiring connector. The AAW harness will expect to connect through the standard wiring connector, with an intact printed circuit
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
Re: Dash Cluster
This is what the printed circuit should look like.
Re: Dash Cluster
Old member
Printed circuit is cut off at the two bottom gauges. Buy new one and everything should be fine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Dash Cluster
If the truck harness is butchered, you may have to hook it back up like it was or fix the problems. A new circuit board may not fix it.
Oh and add a ground wire between the cluster bolt above the speedo and the body of the truck.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Re: Dash Cluster
Demian5 I installed a new wiring harness. Just tying to button everything up . So looks like i need to replace the circuit board to make it work correctly.
Re: Dash Cluster
Do you have the Classic Update kit or the Stock Replacement style. If you have the Classic Update then you will have to change from the amp guage to a volt guage. This will require rewiring how the circuit board attaches to the gauge so you may want to just use what you have and run wires to the other disconnected guage. It was probably disconnected for a reason and you'll have to diagnose that first.
#9 | |
Re: Dash Cluster
Re: Dash Cluster
#11 | |
Re: Dash Cluster
Ramiro |
Re: Dash Cluster
I rebuilt my cluster and installed a new circuit board and a new complete wire harness. But here is a question i have. Did you remove the printed circuit board wire plug? This would be the large plug that goes into the big hole on the back. Sorry if i am going overboard, just not sure if you know what i am referring about. This plug brings all the power and wires to the board and out. It really makes me wonder if they removed the plug and instead just direct wired the gauges.
#13 | |
Re: Dash Cluster
#14 | |
Re: Dash Cluster
Here is my new cluster plug. |
#15 |
Re: Dash Cluster
#16 |
Re: Dash Cluster
#17 |
Re: Dash Cluster
#18 |
Re: Dash Cluster
I notice that youR nr 12 is empty? In mine I have nr 5 empty. I belive nr 12 is ground cable.
#19 |
Re: Dash Cluster
#20 | |
The Older Generation
Re: Dash Cluster
LockDoc
#21 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: Dash Cluster
No. 12 is the battery gauge positive wire in the stock harness. It mates with no. 1 in the harness plug for the other terminal ( remember the word Swede).
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#22 |
Re: Dash Cluster
The one in my picture should be #7 then.... LockDoc
#23 |
Re: Dash Cluster
