I'm just glad to be here!
VSS with a TH350...
OK, I am putting in a LM7 into my truck, but I am using a TH350 for the trans since I had one sitting ready to go.
I have heard that I need to have a VSS signal that goes to the PCM to help avoid stalling the engine under hard breaking conditions. Since the TH350 has no provision for a VSS sensor, HOW DO I get that signal to the PCM? OR - Do I really NEED that signal to the PCM?
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#2 | |
![]() Join Date: Apr 2005
Re: VSS with a TH350...
Let me know.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Thanks Rob. I really wanted to run the stock mechanical speedo too. Let me looking that and I will get back to you. Your part looks like a good deal if I skip the stock speedo.
No worries. LMK.
I'm running mine without the VSS on a TH350. I turned off engine braking in the tune, so no worries with it.
1973 K5, full vert, 6" BDS lift, 35 Mickey T MTs 1984 K10, 8" lift on 35s 2004 3/4 4wd, 33s Toyo Mts, Long Tube headers, 3K multidisk 80e, tons of miles 2011 Yukon XL | Bone stock 2013 Audi Q5 |
Thanks for the input. I have heard that I can do that, but just not sure what I want to do just yet.
Look like Dakota Digital has a 8k per mile pulse generator that is a pass thru that will let me keep my stock speedo. Seems to be cost effective at under $50.
jagsthatrun has this kit, pricey tho for what it is.
http://www.jagsthatrun.com/Pages/Par...ctor-Diff.html I believe the 8k pulse pass thru sender works as well. I am actually not running a VSS at this time, I don't have stalling issues but decel is not as smooth has it could be. But I am running an SM465 manual, not sure how well that will work with an automatic. |
I think that in the tune you can adjust the tune to accept 8000k . That dakota digital piece should work for you.
Who is programing your pcm ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
I have spoken to the tuner, he can program the VSS to accept the 8k pulse signal. For this swap I am just going to have Brent at lt1swap.com do the vats delete and turn the codes off for the trans when I get it done.
Tags |
lm7, th350, vss |
