Old 01-27-2012, 10:35 PM   #1
brans72
how restore brake booster
Anyone wanna throw out there how to restore a power brake booster on a 67 C10 does not have to be 100% correct. Booster is rusty but solid. Thanks Brandon
brans72 is offline   Reply With Quote
Old 01-27-2012, 10:51 PM   #2
DT1
DT1's Avatar
Re: how restore brake booster
Believe me. Re-manufactured brake boosters are cheaper and much safer than trying to do it yourself. Even if you could find a rebuild kit out there, which I doubt, by the time you get it done, you will still be way ahead to just get a reman. I just got one for my 71 and it only cost $90.00.
DT1 is offline   Reply With Quote
Old 01-27-2012, 11:07 PM   #3
brans72
was meaning cleaning up outside as in looks.
Old 01-27-2012, 11:24 PM   #4
jocko
jocko's Avatar
Since you're saying restore - I'll assume you mean something beyond just a re-spray with some gorgeous gray primer and then some color. Eastwood company sells a multi-step paint process designed to replicate the Delco-Morraine (sp?) gold/green tint, if that's what you're talkin about. Taint cheap either. Would suck to put $50 in paint into a used booster and then have it go out at 150K miles, just 15 miles down the road.... Unfortunately, most replacement boosters are not coated like the originals. Some companies carry them, like CPP etc.
Old 01-27-2012, 11:27 PM   #5
71 super
71 super's Avatar
Dont waste yor time with the paint it is crap... Buy a plated booster from CPP or others and call it good. Tried the paint early on a reman booster and after about 6 months (no driving) it was going south. Bought a new plated unit and have not looked back.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 01-28-2012, 12:11 AM   #6
DT1
DT1's Avatar
I agree. Summit sells re-manufactured boosters that are gold (At least the picture is).
Old 01-28-2012, 07:53 AM   #7
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Some were painted black so if you have that one, real easy to do.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 01-28-2012, 10:53 AM   #8
67Slider
67Slider's Avatar
I sandblasted, primed, and repainted mine with the rustoleum engine paint from Autozone, cleared coated it when it dried and I think it looks great. Not stock but my truck isn't either so no big deal. I was into it about $20.
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 01-28-2012, 10:57 AM   #9
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
http://www.brakeboosters.com/
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 01-28-2012, 06:02 PM   #10
red69ss
Burnouts are therapeutic
red69ss's Avatar
I blasted my booster and took the right angle die grinder with a scuff pad on it to the master cylinder since it was still on the truck,I then painted it with cast blast spray bomb. I really like the look of the paint and use it on all my rides...... best pic I have
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 01-29-2012, 03:10 PM   #11
brans72
How do you sand blast without getting anything in the booster? I just wanna clean up the outside for looks and super tight budget with baby on the way guys! Thanks Brandon
Old 01-29-2012, 05:02 PM   #12
rsavage
rsavage's Avatar
I sanded mine, sprayed it with self etching primer, then Krylon stainless steel, then Duplicolor GS 100 gold. Not a perfect match but close enough until I need a new booster.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-29-2012, 05:12 PM   #13
67Slider
67Slider's Avatar
Plug the holes good with a cork/newspaper/saran wrap etc. then blast away. Be careful around the openings. If your nervous about blasting it, degrease real good, scuff it up and go that route.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 01-19-2017, 06:16 PM   #14
buckkoo
buckkoo's Avatar
I'm a huge fan of the Eastwood product, which looks great. Yes, it is a tad pricey, but I've redone 2 brake boosters and numerous other under the hood parts.
buckkoo is offline   Reply With Quote
Old 01-19-2017, 07:34 PM   #15
redbaron
redbaron's Avatar
Here is what we did.
http://67-72chevytrucks.com/vboard/s...d.php?t=661200
Mike
1972 C10 Cheyenne SWB Black Supercharged Project
1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175
1969 Camaro Protouring LS7 T-56 Project
redbaron is offline   Reply With Quote
Old 01-19-2017, 08:19 PM   #16
saxart
saxart's Avatar
Aren't there rubber parts inside a booster? If so, I'm guessing if the outside is old and crusty, then the innards are as well, right? Something to think about when you go to clean up the exterior of a booster.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
